FAQ: Wiring Harness Plugs (What are their names/Where do they go?)
Old Aug 1, 2004 | 08:38 PM
busychild's Avatar
Default What am I and Where do I go....?(game)
This is an MPFI harness I received back from HCP. Can you guess the plugs?
Entire Harness
#13(blurry)
#14/#15/#16/#17
Old Aug 1, 2004 | 08:40 PM
null.'s Avatar
Default Re: What am I and Where do I go....?(game) (busychild)
the green one goes to resistor and the four goes to injectors, and the other ones just plug up to the other harness, take out your DX one and plug and play, only thing that would be different is the injectors and resitor box
Old Aug 1, 2004 | 08:42 PM
Patch's Avatar
Put 9/10 on the alternator, and 19 on the starter, and the rest will just fall into place. I can name about 80% if you need it, but its not hard to figure out, just put the harness on the engine.
Old Aug 1, 2004 | 08:49 PM
busychild's Avatar
Default Re: What am I and Where do I go....?(game) (egb18turbo)
this is the DX harness, just bored and hot in TX
Old Aug 1, 2004 | 08:50 PM
busychild's Avatar
Default Re: What am I and Where do I go....?(game) (Patch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patch &raquo;</TD></TR><TR><TD CLASS="quote">Put 9/10 on the alternator, and 19 on the starter, and the rest will just fall into place. I can name about 80% if you need it, but its not hard to figure out, just put the harness on the engine.</TD></TR></TABLE>
mainly the #12 and what do I work out ont he Si distributor? I am also trying to add the y8 IM at the same time.
Old Aug 1, 2004 | 08:58 PM
Patch's Avatar
1) Injector resistor box
2) Plug into chassis harness on drivers side
3) Wire into ECU for 2 extra injectors for MPFI swap
4) Injector plugs
5) IACV
6) IAT sensor
7) TPS
8) Thermoswitch
9/10) Alternator
11) Oil pressure idiot light
12) Main distributor plug wires, missing two for some reason
13) Coil wires
14) Temperature sensor (instrument cluster)
15) O2 sensor
16) Reverse lights
17) Coolant temperature sensor (ECU)
18) Plugs into chassis harness at passenger side
19) Starter solenoid 'S' terminal
Old Aug 1, 2004 | 09:02 PM
kurinto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patch &raquo;</TD></TR><TR><TD CLASS="quote">1) Injector resistor box
4) Injector plugs
5) IACV
6) IAT sensor
7) TPS
8) Thermoswitch
9/10) Alternator
13) Coil wires
15) O2 sensor
16) Reverse lights
This man is correct...and sticky this and change the title I tried searching for a thread like this when I was doing my swap and this would have helped immensely (not that it was that hard to figure out but would have saved me a lot of time).
ironchef25's Avatar
wow this thread was intresting.. learned a lot.
Old Aug 1, 2004 | 09:06 PM
busychild's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patch &raquo;</TD></TR><TR><TD CLASS="quote">12) Main distributor plug wires, missing two for some reason
wary, wary quick on the headfoot!
except for this everything looks in order. What else is needed?
Old Aug 1, 2004 | 09:16 PM
Patch's Avatar
Two wires for the cylinder position sensor: a blue/green wire that goes to pin C1 at the ECU, and a blue/yellow wire that goes to pin C2.
Old Aug 1, 2004 | 09:22 PM
busychild's Avatar
does it make a difference that a D16y8 manifold was going in instead of the a6?
Old May 13, 2005 | 04:53 AM
EFvtec Yo!'s Avatar
sorry about bringing a topic back from the dead. But, who made you that harness and how much did it cost you? I have a 90 std that i recently did the mpfi swap on and my harness looks like total crap. I need one made like that if i could get it for the right price.
Old Jun 7, 2005 | 08:18 PM
busychild's Avatar
http://www.hcpengineering.com
Old Jun 7, 2005 | 10:56 PM
NikoZai's Avatar
http://www.rywire.com
HCP doesn't even advertise what they do, we back our products 100% with phone support and a lifetime warranty. And i bet we're cheaper if not equal price.
Old Jun 8, 2005 | 05:52 AM
SETI20's Avatar
Good info
Old Jun 8, 2005 | 10:54 AM
NikoZai's Avatar
Default Re: (SETI20)
I'll post a pic of our conversion to show the differences. We're much cleaner.
Notice how long the injector run is and how it doesn't follow the harness wiring.
Also the lack of loom on it, just tape.
Don't see the pins going to the ECU, but i'm sure they aren't crimped on like ours.
We mark all of our plugs so this question never comes up says TPS on the TPS plug etc... Those 2 pins around the intake manifold can be confusing. you certainly don't want your knock wire in your TPS plug and vice-versa
I'll contribute to this... I'll make a H22, K20, Z6, B16 and ITR version of these pics just as soon as i get them on an engine stand. lol
Modified by NikoZai at 12:05 PM 6/8/2005
Modified by NikoZai at 12:07 PM 6/8/2005
Modified by NikoZai at 12:09 PM 6/8/2005
Old Jun 8, 2005 | 11:56 AM
Stoich's Avatar
Default Re: (NikoZai)
wow those are a great idea sweet diagrams!
Old Jun 8, 2005 | 01:40 PM
vegaskurt's Avatar
Default Re: (Stoich)
Can we put this in the faq?
Old Jun 8, 2005 | 01:43 PM
vegaskurt's Avatar
Default Re: (vegaskurt)
Oh and your question about the y8...
You can use this on the y8 if you use the A6 injectors. The y8 injectors are obd2 and have a different clip.
The wire for the map sensor will have to be extended to use the y8 map.
The IAT wire will have to be extended... and put somewhere.
Just read, http://www.geocities.com/joeyp....html
Old Jun 8, 2005 | 04:14 PM
sanimalp's Avatar
$cat /dev/urandom
ive got a question about the amount of wiring harness you guys need when you do the swap. im interested in sending a dx harness to rywire at some time this summer, but do i need to send the whole harness from the ecu to all the sensors? or can i just send the portion of the harness that unplugs from the passenger side shock tower? i want to pull a harness out of a donor car and send that so that i have a minimal amount of downtime.
is it this portion? i know this car is an si, but i need to know for a dpfi-&gt;mpfi swap on a dx where i pull it. cause i already messed with a car in the junk yard as far as pulling it from the ecu plug out, and that was kinda a pain.. this is for a friends dx, thanks guys
Old Jun 8, 2005 | 04:27 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (sanimalp)
well i guess to answer my own question and for anyone else who has this question, it looks like you pull it where i circled, atleast from the pictures earlier in this thread.
Old Jun 8, 2005 | 08:32 PM
busychild's Avatar
yes and from the opposite side, to the right of the master cylinder.
Old Mar 14, 2012 | 02:30 PM
Ottawabook's Avatar
Default Re: FAQ: Wiring Harness Plugs (What are their names/Where do they go?)
pictures too ka poo
Old Mar 14, 2012 | 07:11 PM
KINGVEM^^ED6's Avatar
What did u expect after.seven years
Old Jul 7, 2013 | 05:03 AM
entoy's Avatar
HI do you have any idea regarding the file?
how to open?thanks advance?
fog raw
29
Oct 10, 2011 08:27 PM
dagle
Audio / Security / Video
Feb 3, 2008 05:42 PM
Memnoch
Dec 12, 2007 08:05 PM
89sparks
Jun 19, 2007 09:33 PM
turbo sol
May 23, 2003 06:21 PM
