A/C Evaporator Drainage Problem
this is on a 1997 civic.
the passinger side floor is soaked and its not antifreeze so i know its not the heater core and the only other thing right there is the evaporator. so i put the car on a lift and run it with the A/C on for 15 minutes and come back. there is no water coming out of the drainage for condensation on the evaporator. i havent heard of this problem before but im assuming the drainage is clogged. has anyone had to deal with this before or know how to?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua »</TD></TR><TR><TD CLASS="quote">the drain hose came undone from the evaporator inside the car below the glove box.</TD></TR></TABLE>
sounds about right to me. its probably easy to see under the glovebox right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicFerioSiR »</TD></TR><TR><TD CLASS="quote">sounds about right to me. its probably easy to see under the glovebox right?</TD></TR></TABLE>
yup
yup
