blaster coil with stock ignition- already searched!!
Old Aug 1, 2004 | 04:51 PM
mrod006's Avatar
Default blaster coil with stock ignition- already searched!!
i am considering swapping an msd blaster coil with the msd distributor cap for the stock coil since it took a dump. would this be a good idea? will i fry anything else if i run this setup?
my setup is a 00 y8 with a greddy kit pushing 7 psi.
Old Aug 1, 2004 | 05:25 PM
murtnabila's Avatar
Default Re: blaster coil with stock ignition- already searched!! (mrod006)
up since I believe I misunderstood what you were sayin
Modified by murtnabila at 6:59 PM 8/1/2004
Old Aug 1, 2004 | 09:00 PM
mrod006's Avatar
Default Re: blaster coil with stock ignition- already searched!! (murtnabila)
what i meant to say was that will i hurt anything else in my ignition system by switching to an msd external coil.
Old Aug 1, 2004 | 09:33 PM
hondaeg8's Avatar
your using msd with the internal coil?
if so...how?
Old Aug 1, 2004 | 09:36 PM
Donkey85's Avatar
Default Re: blaster coil with stock ignition- already searched!! (hondaeg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 &raquo;</TD></TR><TR><TD CLASS="quote">your using msd with the internal coil?
if so...how?</TD></TR></TABLE>
if i'm understanding him thats not what hes saying hes talking about running an EXTERNAL coil instead of the internal coil
Old Aug 1, 2004 | 09:40 PM
hondaeg8's Avatar
if your saying that your thinking of getting an msd set up instead of the stock ignition set up, then yeah...you'll be fine. i've ran the msd ignition kit on all my honda motors. never had a problem and it idles good.
Old Aug 1, 2004 | 09:48 PM
hatchi's Avatar
you wanted to know if you can run an external coil coz you're internal coil took a dump on you. It will work just make sure you install it correctly
ATS*Mark
Jan 31, 2005 08:11 PM
marques4130
May 10, 2003 12:16 AM
marques4130
May 9, 2003 06:24 PM
Blown90hatcH
Jan 10, 2003 09:11 PM
