h22 turbo
Old Aug 1, 2004 | 04:24 PM
101block92's Avatar
Default h22 turbo
i have a h22 in my 92 accord and just got my turbo but i cant seem to find a good way to run the pipe from the press. side of the turbo to the intercooler. the only way i see is to remove the ac compresser but i cant do that because my wife would kick my ***!
Old Aug 1, 2004 | 04:29 PM
madd's Avatar
Default Re: h22 turbo (101block92)
a/c is for whimps...i hope you arn't gonna run much boost on that h22a (unless you've already done your research!)...but i hope you choose the turbo over a/c...the wifey will surely understand your need for speed!
Old Aug 1, 2004 | 04:31 PM
101block92's Avatar
Default Re: h22 turbo (madd)
8 psi kit from turbonet. and the reason why my wife would kick my *** is because i have a 16 month old girl that would die in this heat
Old Aug 1, 2004 | 04:43 PM
madd's Avatar
indeed...bad turbo'ing the family car if the kit is for the h22....i would think that they would have made it to fit with the a/c...i believe most kits do these days. then again they probably didn't account for an accord with an h22. you better watch that high compression and ringlands, but you might be screwed on the piping deal
Old Aug 1, 2004 | 05:16 PM
JDM.Accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 101block92 &raquo;</TD></TR><TR><TD CLASS="quote">8 psi kit from turbonet. and the reason why my wife would kick my *** is because i have a 16 month old girl that would die in this heat</TD></TR></TABLE>
Hope your wife and 16 month old like fireworks, cuz at 8 psi on stock H guts, that's what you're gonna have
Old Aug 1, 2004 | 10:33 PM
Nick H's Avatar
New User
Default Re: h22 turbo (JDMAccord2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMAccord2nr &raquo;</TD></TR><TR><TD CLASS="quote">
Hope your wife and 16 month old like fireworks, cuz at 8 psi on stock H guts, that's what you're gonna have </TD></TR></TABLE>
8 psi is safe if properly tuned...wouldn't personally go over that, but it'll be ok...
also, just throwing an idea out, try mounting the turbo in the opposite direction (compressor on passenger side and exhaust housing on driverside)...of course you'd have to get a new downpipe custom made, as well as new charge piping custom made...but hey, you'd still have your ac
Old Aug 2, 2004 | 07:47 AM
JDM.Accord's Avatar
Default Re: h22 turbo (Nick H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H &raquo;</TD></TR><TR><TD CLASS="quote">
I wouldn't run over 6 psi on a stock h. I had a friend blow his up at 8psi. It will last a little while but I'd give it less then a year before it pukes
Old Aug 2, 2004 | 02:19 PM
Nick H's Avatar
New User
I wouldn't run over 6 psi on a stock h. I had a friend blow his up at 8psi. It will last a little while but I'd give it less then a year before it pukes </TD></TR></TABLE>
i'll personally be running at about 5 psi daily...maybe 8 at the track...should make some pretty nice numbers with such a setup...
Old Aug 2, 2004 | 02:34 PM
JDM.Accord's Avatar
i'll personally be running at about 5 psi daily...maybe 8 at the track...should make some pretty nice numbers with such a setup...</TD></TR></TABLE>
Yeah 5 would be safe daily. But for this guy I get the idea this car is his only ride. You don't want to blow up your only form of transportation, especially with a wife and kid to transport
Old Aug 2, 2004 | 11:37 PM
H22CB7's Avatar
I agree
M1SCO15
Jan 7, 2007 07:51 AM
gustavito1986
Sep 28, 2006 03:59 PM
Subwarrior
Mar 19, 2005 02:07 PM
abeaujuin
Jun 16, 2003 05:20 AM
Sleeping4drLS
Feb 5, 2003 04:44 PM
