D16A to D16Z Coolant Sensor Swap
Old Nov 28, 2001 | 07:21 AM
D-Man's Avatar
Default D16A to D16Z Coolant Sensor Swap
Can i use the coolant sensor mounted on thermostat housing on the D16Z with the wire harness from my 91 Si? does it matter which way i hook up the two wires to it?
Old Nov 28, 2001 | 12:46 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: D16A to D16Z Coolant Sensor Swap (D-Man)
You talking about the fan switch right?
Just rewire to the new switch on the thermo housing.
Don't matter which way you wire it.
Old Nov 28, 2001 | 12:56 PM
D-Man's Avatar
Default Re: D16A to D16Z Coolant Sensor Swap (Mista Bone)
yeah,the big one right above the oil filter,next to oil pressure switch on D16A...its not threaded for sensor,casted closed on my D16Z,needs to be drilled and tapped,but i dont want to risk it cause short block is built and it would really suck if i screwed up the block trying to tap and thread it....anyway,thanks! good to know it will work on the smaller sensor on thermostat housing.
Yuta
Nov 5, 2015 12:16 PM
jtrig
May 31, 2011 06:25 PM
zx9rbart
Jul 2, 2006 08:15 PM
paybac4223
Mar 15, 2004 05:35 AM
zCivic
Jul 29, 2003 08:36 AM
