Fuel Cut after VAFC install
Ever since my VAFC has been installed I am hitting a rev limit or fuel cut in every gear at 7800-7900. Prior to install I had no issues and pulled to 8200 just fine.
Set up....
LS/Vtec
PR3 ECU
Walbro Fuel Pump
AEM Rail
B&M Regulator
Stock Injectors
VAFC is wired correctly and fuel filter has been changed. Any ideas?
BTW... car feels slower with the VAFC
Set up....
LS/Vtec
PR3 ECU
Walbro Fuel Pump
AEM Rail
B&M Regulator
Stock Injectors
Well, it would seem to me that since everything was kudos before the AFC install, then the fault lies either in the installation of the VAFC or in something that was changed via it.
What purpose did you have to install the AFC? Are you going to take your car to get it tuned with it? Also, what changes have you already made with it?
I do plan on dyno tuning it and no real changes were made. Today, I played with my FPR and it seems to have gotten rid of the fuel cut. Any ideas why this worked?
on apex-i's vafc theres an option for redline... are you sure you have it set at 8200 or whatever your redline was?
i remember 1 time my boys were fkingh w. me and set it down to 6000
would bounce off the limiter
Hello please somebody help me with the wiring and installation manual for my v-afc II...i bought it without manual and now cant install....please if someboy has one help me...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark_Samurai »</TD></TR><TR><TD CLASS="quote">Hello please somebody help me with the wiring and installation manual for my v-afc II...i bought it without manual and now cant install....please if someboy has one help me...</TD></TR></TABLE>
Don't hi-jack other people's threads like this.
All of the Apex-i manuals are available online in .pdf format.
Go to Apexi USA
Go to Apexi USA
there is a v-afc installation manual for the apexi v-afc 1 but the v-afc II have 3 wire more and is diferent...and in the apexi webside doesnt appear the wiring and installation manual for the v-afc II.-..thanks
