Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
need a little info about springs
Old Aug 1, 2004 | 11:06 AM
99lsvtec20's Avatar
Default need a little info about springs
i wanna a little info about stiffer springs than the regular ground control we buy. i want to build my car for autocross,. info and links will be nice
Old Aug 1, 2004 | 12:16 PM
Vitt1's Avatar
Default Re: need a little info about springs (99lsvtec20)
What kind of info? If the Q is how stiff is too stiff, you're find that it's all subjective. It comes down to what can you live with if the car is a daily driver.
https://honda-tech.com/zerothread?id=353425
http://www.norcalcrx.org/tyson/coilover.html
Old Aug 1, 2004 | 12:59 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: need a little info about springs (Vitt1)
One thing you should be careful of with deciding on a setup is what shock you'll be matching it to. A really stiff spring on a stock shock will ride like crap, and will blow out your shocks quickly. How experienced are you for tracking/autoxing, as that will also make a difference. I'm guessing you're a bit of a noob to it, just because you'd probably already know the answer to your question if you were experienced. Given that, don't worry about the $1500 coilover setups, as you won't require the adjustability of said units and you won't be using them to their full potential. Something cheaper, maybe Koni Yellows with GC springs, or even something as simple as ITR shocks/springs (I'm assuming you have a non-R teg from your screenname and previous posts about the OBX LSD) will be a good starting point.
andytay83
Suspension & Brakes
Mar 30, 2012 02:22 AM
5800vtec
Apr 14, 2008 11:13 PM
HipHapa-Eg
Honda Civic (2006 - 2015)
Nov 16, 2007 10:11 AM
ss20gsr
Suspension & Brakes
Jul 26, 2005 02:35 PM
EG TYPE-R
Oct 10, 2003 07:06 PM
