knocking sound when i start my car?????
Old Aug 1, 2004 | 08:12 AM
cbrodac0424's Avatar
Default knocking sound when i start my car?????
ok when i went outside to start my car this morning i noticed that i made a really bad knocking sound coming from the motor but i stopped like after 2 seconds i have no clue what this is anyone else have this problem i dont think it is my rods or it could be????
Old Aug 1, 2004 | 08:19 AM
StupidSlowRSX's Avatar
Default Re: knocking sound when i start my car????? (cbrodac0424)
congrats!!
your a victim of a spun rod bearing
do not drive or start the car anymore more, for fear of warping your craank.. If you continue to drive it you will need a new crank along with bearings... At the moments you probably just need new barings
Old Aug 1, 2004 | 08:25 AM
Default Re: knocking sound when i start my car????? (StupidSlowCRX)
its not a spun rod bearing i already asked many mechanics if thats what it could be but they said it doesnt sound like it but i dont know it could
Old Aug 1, 2004 | 08:30 AM
slowly rev the engine up till around 3k.. do you hear a strange pinging/tapping sound there too? I Jus spun a bearing on my zc... Another way to check is to do an oil change. You will have metal shavings if you spun a baring
Old Aug 1, 2004 | 08:50 AM
520_Motorsports's Avatar
I agree with stupidslowcrx the reason you get the sound when first starting your car is because you do not have oil flowing it is all at the bottom of the oil pan you get the tapping noise then the oil pressure builds up and the noise goes away hang around 3k rpm if you got a tapping noise you most likely have a spun rod bearing
Baron55
Jan 9, 2007 08:10 AM
SPOOLINmatt
Mar 14, 2006 01:01 PM
staticrex
Aug 3, 2005 08:20 PM
b16a27
Jun 7, 2005 08:15 PM
Blown90hatcH
Nov 15, 2001 12:36 PM
