How to loose the bottom bolt for 95 accord lx 4 cyl fuel filter
i have a 95 accord lx non-vtec 4 cyl, and try to change the fuel filter myself. what is the best way to loose the bottom bolt of the filter? (it seems that i need some wrench that has very long extension.)
the way i've thought about doing is to loose the banjo bolt first, then remove the fuel clamp, and pull the filter out a bit so my wrench can reach it, then loose the bottom bolt, but i am not sure if it's the right way to go about it.
what do you guys recommend? would you be specific about the tools (and sizes) i will need?
and lastly, how do you torque the bolt back to factory setting? i do have a 3/8 torque wrench, but don't know how it can be applied in conjunction with an open wrench.
thanks a lot for your help!
Nihsnek
17
Dec 30, 2011 02:40 PM
