Leaking tranny fluid
Hi all,
I've had this problem for quite a while, thought it was fixed but it still isn't. I developed a leak around the seal where the passenger half shaft comes out of the tranny.
I typically would lose 1-2 qrts of tranny fluid driving to, participating and driving home from an autocross. Well when I put in my ATS 1, 2 and FD I replaced the seal and put in a new retaining clip, but am now leaking again. I can literally click the driveshaft in and out by hand. I don't have a problem with the driver's side halfshaft seal. Could this be coming from my Kaaz LSD? Is there a better way to lock in the driveshaft? What would keep popping it out?
Any and all help is greatly appreciated.
BTW, I can now re-fill my tranny fluid in less than 15 minutes start to end.
[Modified by TodaSi, 8:37 AM 11/28/2001]
Could be the diff.. or the inner joint.. or the circlip on the inner joint's spline.
My B18 CRX had the same problem. I replaced the seal twice before I decided to replace the circlip on the axle. Once spent the chump change on the clip(like $1.00) the problem was solved.
BTW if it's the diff, what do I do to correct it?
jdmstyleEJ6
12
Apr 2, 2010 08:07 PM
ghost_ryder35
14
Aug 25, 2005 01:08 PM
VTEC-DA
Sep 6, 2003 11:43 AM
