exhaust will not stop smoking.
Old Jul 31, 2004 | 09:04 PM
URA91hatch's Avatar
Default exhaust will not stop smoking.
my exhaust on myu 91 civic dx will not stop smoking..i think the oil is leaking because i go through oil fast....but i need to know where it might be leaking at.if anyone has had similar problems or know what might be causing this please let me know....thanks
Old Jul 31, 2004 | 09:38 PM
VtecKiDD's Avatar
Default Re: exhaust will not stop smoking. (URA91hatch)
what motor, mileage? in any case its probably Piston rings = motor needs a rebuild. Do a compression test on the motor. other posibilities could be valve seal, but valve seals usually only smoke when the car coasts down. If it smokes at idle an whenever you get on the gas, oil is getting by the pistons (blow by) somewhere. compressi0on test only way to know for sure. Pull your plugs see if there is oil on them (there shouldnt be)
Old Jul 31, 2004 | 09:42 PM
jkeno112's Avatar
Default Re: exhaust will not stop smoking. (VtecKiDD)
could be the rings. Run a compression test like VTeckidd said. by the way what color smoke is it? Could also be a crack head gasket. Let us know the outcome
Old Jul 31, 2004 | 10:39 PM
1badcrx's Avatar
I was having a simillar problem with my crx, yet only in the higher RPM's, i went to Auto Zone and got some stuff called "smoke b gone", and it has takin care of the problem. Yet you may have a more serious engine problem, still I would try the Smoke stuff, it goes right into your oil, and it hasnt caused any problems.
Old Aug 1, 2004 | 06:27 PM
bucketheadCRX's Avatar
Default Re: exhaust will not stop smoking. (1badcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1badcrx &raquo;</TD></TR><TR><TD CLASS="quote">I was having a simillar problem with my crx, yet only in the higher RPM's, i went to Auto Zone and got some stuff called "smoke b gone", and it has takin care of the problem. Yet you may have a more serious engine problem, still I would try the Smoke stuff, it goes right into your oil, and it hasnt caused any problems.</TD></TR></TABLE>
..only i tried this stuff by STP called "Smoke Stopper" and it has actually helped quite a bit..i know i need some work but..i really want to swap out the motor if i can ever save enough money so..cheap fixes like this will do while i keep saving
Old Aug 1, 2004 | 06:30 PM
green91's Avatar
mine does it over about 5k rpms
Acura850.
Feb 11, 2009 12:18 PM
8YourV8
Dec 28, 2006 01:05 PM
RacerRex
Dec 2, 2006 05:19 PM
Sassafrass
20
Jul 18, 2006 07:06 PM
luckypon7
Sep 4, 2003 05:36 AM
