throttle cable/TB prob. weird idle
Old Jul 31, 2004 | 08:25 PM
rtpassini's Avatar
Default throttle cable/TB prob. weird idle
OKAY heres the problem.
(h23 into sol)
idle problem. i know what it is. but not quite sure how to fix it. i think my TB is gunked up so it cant get the right tension/slack. or its the spring on the TB because it isnt letting the plate close enough to its proper position. i have to push it(the little thing the throttle cable attaches to on the TB) to close it all the way. its such a small amount. but it makes a differnece. any ideas. when i swapped. i used the d series throttle cable that came on the sol and flopped the holder upside down.
Old Jul 31, 2004 | 09:54 PM
IVI's Avatar
IVI
Default Re: throttle cable/TB prob. weird idle (rtpassini)
1st clean the throttle body
2nd adjut the cable so its not tugging on the butterfly to keep it open, it has to be fully closed or your going to get an erratic idle sometimes.
Old Jul 31, 2004 | 11:40 PM
rtpassini's Avatar
thats just it though. i cant get it to fully close. so im thinking either gunked up TB or the spring just isnt strong anymore
Old Aug 1, 2004 | 12:31 AM
IVI's Avatar
IVI
Default Re: (rtpassini)
disconnect the cable to see if its the cable that is making it stick
if it is you can either fabricate a bracket to better adjust it or get a new cable (20 bucks)
bk7794
13
Jun 21, 2012 08:17 PM
Team PHATBOYZ
Jun 17, 2010 01:56 PM
bseries_beast
Jul 2, 2004 09:25 PM
crazy eyez killa
Mar 3, 2004 01:11 PM
integra99blue
Jul 16, 2001 07:56 PM
