best way to take off chip in a ecu
Old Jul 31, 2004 | 06:36 PM
accord2nv's Avatar
Default best way to take off chip in a ecu
im tryin to take off a chip i my 95 poa ecu not sure what chip but im putting the real mugen chip not the **** you find on ebay.but im trying to take it off not sure if i should just yank it off any sgtns..
Old Jul 31, 2004 | 07:29 PM
fw190bvi's Avatar
Default Re: best way to take off chip in a ecu (accord2nv)
unless you an electricain, you should have that done professionaly......cause if you cant soder, your fuct............and BTW: Mugen never ever made chips for accords
Old Jul 31, 2004 | 09:06 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord2nv &raquo;</TD></TR><TR><TD CLASS="quote">im tryin to take off a chip i my 95 poa ecu not sure what chip but im putting the real mugen chip not the **** you find on ebay.but im trying to take it off not sure if i should just yank it off any sgtns..</TD></TR></TABLE>
It should be in a socket? Just pry it out as evenly as possible.
Old Aug 1, 2004 | 07:48 AM
madd's Avatar
should is be soldered on to the board, taking it out is nothing difficult. i do electronics reapair, but anyone can pretty much do it. you will need a soldering iron, solder braid (nothing but copper braid), and some solder flux (basically, itll let the solder flow easier allowing you not to burn the traces off the board). i suggest you get some junk PCB and practice on it. simply dip the solder braid into the flux....lay the braid next to the pin/pins you want to desolder...apply your tip to the braid and push against the pin...and watch the solder flow onto the braid and off the pin. you may need to use some needle nose pliars to loosen the pin up. you can pick all that stuff up at your local over priced Radio Shack, or if you happen to live near milledgeville, GA i wouldnt mind helping out. whatever you do good luck
Old Aug 1, 2004 | 01:36 PM
Nick H's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord2nv &raquo;</TD></TR><TR><TD CLASS="quote">not sure what chip but im putting the real mugen chip not the **** you find on ebay.</TD></TR></TABLE>
a real mugen chip eh? well, when they make one, let us know how it feels...until then, you are buying the same **** that is on ebay...good luck budy
panchlow
May 18, 2011 07:34 PM
Exempt
Engine Management and Tuning
10
Oct 3, 2008 11:11 AM
jwaked
12
Dec 29, 2004 09:22 AM
Sp33dStarVirus
May 30, 2003 08:58 PM
