Cd player feedback
I have A pioneer deh-p9600mp and when i turn it off and on all my speakers and my subs make a pop noise and it makes the noise yoiu hear when the cd player reads the disc and makes poping noise it did the same thing i figured out it was'nt my amps but it was my cd player so i put my new deh-p9600mp work fine for 2 days and when connecting my speakers to the correct channel on the amp and it started again, I put my brothers amp in did the same thing, checked the ground with jumper cables to the battery, checked the ground and power on the cd player with same method, I also installed another capacitor shortly after this problem started but i took it out and it still does the same. and when i connect my speakers to the cd player amp it does not do this but only when connected to the preamp out puts?
What kind of amp/amps? sounds like bad RCAs, or RCA routing, try this, run a set of RCAs from HU to amp/amps down center of car on top of everything, just a test,also check for groundloop run 18 to 16 gage wire from HU case to amp/amps case, try this ,let me know.
hope this helps. 94
hope this helps. 94
i have an 2 year old pyle 4 channel 800 watt and Pyle PLA2570 2000 watt and when i hooked up my brothers amp to my car sme problem but when i hooked up my amp's to his car it didnt do it. I ran the audio cord through inside of the car over the cinter console but it still did it i tried to ground the frame of the cd player to the amp but it still does it. I need any idea i can get i dont wanna keep buying new cd players thanks alot man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mood513doom »</TD></TR><TR><TD CLASS="quote">i have an 2 year old pyle 4 channel 800 watt and Pyle PLA2570 2000 watt and when i hooked up my brothers amp to my car sme problem but when i hooked up my amp's to his car it didnt do it. I ran the audio cord through inside of the car over the cinter console but it still did it i tried to ground the frame of the cd player to the amp but it still does it. I need any idea i can get i dont wanna keep buying new cd players thanks alot man</TD></TR></TABLE> Well the only other thing I can think of to try, [ you have tryed everything else] try your brothers HU in your car with your amps.
sorry none of this is helping, maybe this last thing, it's always the last thing you try
94
94
RotaryPWR
Audio / Security / Video
Jun 13, 2008 08:19 AM
