turn key no power.....
Old Jul 31, 2004 | 02:51 PM
KevronsEG's Avatar
Default turn key no power.....
ok guys heres the setup
1988 crx hf
JDM d15b
crx si tranny
obd0 still
pm6
i got everythign ready and i go to turn her over and i put key forward and i get brake light and seatbelt light thats it. So no power to ECU right? what can i check or do to see where my power is not making it to ecu. it comes off battery then to engine bay fuse box and into fire wall so i have no idea what to look for all my grounds are good thermo. ground, valve cover/core suport ground is good what else can i look for. any certain fuses or anything
Any info is great THANKS GUYS
Old Jul 31, 2004 | 04:59 PM
4inspeed's Avatar
Default Re: turn key no power..... (IAmTheRealKevron)
does it crank?
well just in case make sure your ecu is plugged in TIGHT.... just make sure the plug is all the way in.... sounds dumb but it has happened.
dillbrit
Jul 11, 2011 08:51 PM
TBoDelSol
Nov 20, 2005 01:47 PM
vtecnition
Sep 6, 2005 09:42 PM
EKRacer
Mar 28, 2004 02:27 AM
KevronsEG
Apr 21, 2002 01:49 PM
