Anyone know where I can get the tool to change valve springs w/ out removing the head?
Old Jul 31, 2004 | 01:26 PM
DragII's Avatar
25 Year Member
Default Anyone know where I can get the tool to change valve springs w/ out removing the head?
the part that hooks to your air compressor...I haven't been able to find one, I've been searching tool sites under valve, and valve holder
Old Jul 31, 2004 | 01:37 PM
ZygSpeed's Avatar
Default Re: Anyone know where I can get the tool to change valve springs w/ out removing the head? (.D2)
Maybe a spark plug adapter/hose/extension (with a quick connector) from a compression tester?
Old Jul 31, 2004 | 02:43 PM
DragII's Avatar
25 Year Member
Default Re: Anyone know where I can get the tool to change valve springs w/ out removing the head? (zygspeed
if that will work, I'd be set because i have one of those laying around...is that basically all it is? A spark plug fitting w/ a hole in it to filll w/ air?
Old Jul 31, 2004 | 02:47 PM
ZygSpeed's Avatar
I've seen willard use something like that while having someone keep the cylinder pressure at about 100 psi (it will leak a bit) while he used a spring compressor to change springs/retainers/holders.
Give me a call tomorrow noonish or so about that front piece, so we can get together in the afternoon.
Thanks, Ed
P.S. These are on tomorrow afternoon
12:00 pm Speed Touring Car Championship Portland
1:00 pm Speed GT Championship Portland
Old Jul 31, 2004 | 03:14 PM
KayOs's Avatar
Try sears, they have all sorts of compressor attachments.
Old Jul 31, 2004 | 03:27 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Default Re: (KayOs)
Compression tester attachment
Old Jul 31, 2004 | 06:39 PM
DragII's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">P.S. These are on tomorrow afternoon
*sets tivo*
and thanks for the help boys and girls
Old Jul 31, 2004 | 06:55 PM
Dogginator's Avatar
Daisy... Daisy...
I've heard of people feeding rope into the cylinder and then turning the crank to hold the rope against the valves. If you do use air, you don't need 100 psig to hold the valves in place. I used 30 psig when I did mine.
Old Aug 1, 2004 | 10:05 PM
ITR-00-1457's Avatar
Default Re: Anyone know where I can get the tool to change valve springs w/ out removing the head? (Dogginat
The rubber adapter tube from a compression test kit will work, you just have to remove the valve.
MIsterE533
10
Sep 14, 2010 07:18 PM
averyvm
Apr 7, 2008 06:57 PM
GsR92HaTcH
Dec 20, 2006 09:11 PM
SUB-0 H23
Mar 15, 2004 07:45 PM
Evs-One
11
Oct 25, 2002 05:27 PM
