People w/ the Mugen Rear sway bar(26mm).
Old Nov 27, 2001 | 09:48 PM
DarthLuder's Avatar
New User
Default People w/ the Mugen Rear sway bar(26mm).
After installing the bigger bar I noticed the bar and the stock exhaust are very close to each other. Is this normal? Did anyone remove that not so well designed heat shield?
Overall best upgrade I did so far. Handling is alot better but ride quality got alittle worse. U will feel every bump u come across. But who cares Handling got alot better compared to stock. I'm 100% satisfied with the bar.
Old Nov 27, 2001 | 09:56 PM
Mike M's Avatar
Founding Member
Default Re: People w/ the Mugen Rear sway bar(26mm). (O0oToOKo0Oo0OR555)
No problems here, I have both 26mm front and rear and love them
Old Nov 27, 2001 | 10:02 PM
DarthLuder's Avatar
New User
Default Re: People w/ the Mugen Rear sway bar(26mm). (TypeRmsm)
TypeRmsm
No problems here too I was just wondering is the bar suppose to be that close to the exhaust piping. How was your fit?
[Modified by O0oToOKo0Oo0OR555, 7:02 AM 11/28/2001]
Old Nov 27, 2001 | 10:04 PM
nEoMuGen's Avatar
I heard lots of positive comments on the rear.....but how is it when it paired up with the front? Handling wise...pro and con?
Old Nov 27, 2001 | 11:44 PM
Mario's Avatar
if its too close then you might have it upside down.
Old Nov 28, 2001 | 12:12 AM
WayneGro's Avatar
Default Re: People w/ the Mugen Rear sway bar(26mm). (Supersonic DC2)
Does the 26mm bar give you to much oversteer? Some people have mentioned your tail end will swing out very easily, most say it's perfect.
I have Mugen lowdowns, and spoon RSTB. Do you guys think it would be a good upgrade?
Old Nov 28, 2001 | 02:01 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: People w/ the Mugen Rear sway bar(26mm). (WayneGro)
depends on driving style. i have the 26mm out back, with a 21mm up front, and i think it is neutral. a cople of people that drovemy car said it oversteered like crazy. i gues it's all in how you brake. imho, a bigger bar up front defeats the purpose of the of the rear bar, especially if theyy are the same size.
Old Nov 28, 2001 | 02:45 AM
arren123's Avatar
Since you have the Mugen lowdowns, you can set them so you have just the right amount of oversteer. It depends on your tire pressures and your Mugen settings.
At autoX I like the Mugens at 4 front/ 5 rear.. For the street 3front/3rear to make it a little safer so I don't get as much oversteer. With a 4f/5r setting and 40 psi front/ 38 psi rear my car oversteers very nice at the limit.
JDM_Type-R
Mar 22, 2004 09:34 PM
WarrenB
Jan 27, 2004 03:20 PM
BudMan
Jan 23, 2003 11:11 AM
ITR#132
Sep 1, 2002 06:30 AM
EleanoR
Mar 6, 2002 03:23 PM
