Hyper Revving 1.8L "B20" VTEC?
Old Jul 31, 2004 | 12:25 PM
TougeSPEC_DC2's Avatar
Default Hyper Revving 1.8L "B20" VTEC?
1.8L "B20" VTEC - I know that makes no sense. Unless, you put a B16 or B18 (VTEC) head on a B20B/Z bottom end, bore it over to 84.5mm, and swap the B20 crank w/ a B16B crank; THEN, you would have a 1.8L "B20" VTEC. Now, what is the point of doing all that? Hondas are well known for their undersquare motors that can rev to the sky - except for the CTR's B16B, which is slightly oversquare. The problem w/ undersquare motors is their "inability" to rev even higher due to the higher piston speeds, SO what if you make an oversquare "B18" (my frankenstein 1.8L B20/VTEC) - you have the capability of revving NOTORIOUSLY high! No gains in torque, but as we all know, higher revs means higher horsepower (assuming torque can be held up to certain rpm). Imagine a 11,000 or even 12,000 rpm redline out of my "B18"?
Has anyone ever contimplated this (or am I alone)? Any thoughts or comments?
Old Jul 31, 2004 | 03:02 PM
aj99si's Avatar
Default Re: Hyper Revving 1.8L "B20" VTEC? (TougeSPEC_DC2)
You are better off just using a b16 and sleeving it and running a bore of 84 to 85mm.
Old Jul 31, 2004 | 04:41 PM
onePOINTsix's Avatar
Default Re: Hyper Revving 1.8L "B20" VTEC? (aj99si)
so whats the point of revving higher, most cams arn't desinged to make power past like 9k anyway
Old Jul 31, 2004 | 06:48 PM
mmuller's Avatar
Mad Scientist
pointless
Old Aug 5, 2004 | 07:10 PM
96MidoriHatch's Avatar
Default Re: Hyper Revving 1.8L "B20" VTEC? (Sideout)
have cams made for that app then
Old Aug 5, 2004 | 09:00 PM
builthatch's Avatar
MiG-21 superfan
Oiling could become a HUGE problem at rpm levels such as this, unless you have a solution other than using an OE pump...
What would you use to tune @ rpm levels past 10K? I don't know of any engine management, other than exotic motec setups or maybe pectel...
RPM levels like the ones we are talking about here can only be attained with ultra light weight components scattered throughout the engine-
lightweight valves, hollow cams with possibly no lo lobes, Ti retainers, some sort of VERY special valve springs in terms of pressure, Ti rods, etc...
Your cam profile would have to be extremely radical and furthermore, the porting would be something spectacular to actually allow the motor to work as an effective pump, NA, at these types of RPM levels...
Something like this might work if you need maximum HP for a touring car and have an unlimited budget for parts, r&d, and tear down after a few hours of use...
Shaunathan
31
Feb 4, 2012 10:57 AM
JoSi
20
Oct 23, 2006 06:16 AM
B18C-VTI_R
Oct 20, 2004 03:57 PM
KilaB18C
Oct 15, 2004 09:08 AM
d16y8EL
Feb 6, 2004 09:43 PM
