leaking tranny oil!!
Old Jul 31, 2004 | 11:18 AM
alleyezonme's Avatar
Default leaking tranny oil!!
my friend has a b16 in his crx (lopezboard)... there is a steady stream of gear oil coming out of the half circle flywheel cover on the bottom of the tranny. he didn't bottom out to break anything, and he wasn't driving hard. it just started leaking. has anyone had this problem before? does anyone know what it is or how to fix it? thanks
Old Jul 31, 2004 | 12:05 PM
A1's Avatar
A1
Default Re: leaking tranny oil!! (bumpincivic20)
half shaft seal<<<
honda connection
5511 mission st.sf,ca.
415/5871079
Old Jul 31, 2004 | 12:13 PM
Default Re: leaking tranny oil!! (d16why8)
about how much do you think that would cost? is it easy to fix? what does it look like? any info on this would be appreciated... ill search too
Old Jul 31, 2004 | 03:16 PM
ICeDoUt's Avatar
Yea its me, my tranny is gushin out gear oil, and the steady stream was not coming from my intermidiate shaft. Its such an odd place for the oil to be coming out of, its basically on the very bottom of the tranny closets to the block where the flywheel cover plate thing is. Anyone wiht any ideas?? should i jsut get a new tranny?
Old Jul 31, 2004 | 07:42 PM
Dan GSR's Avatar
Default Re: leaking tranny oil!! (ICeDoUt)
i've had this happen to a customer/friend
throw out bearing blew up at the track, a piece of it became a projectile, and pierced a hole in the transmission casing right behind the flywheel
lets hope you don't have the same problem
luckily i was able to save the transmission, just welded the hole
Old Aug 1, 2004 | 06:19 AM
ICeDoUt's Avatar
Default Re: leaking tranny oil!! (Dan GSR)
holy crap that sounds nasty, but i wasn't even driving it hard, i didn't even get to run at the track today because of it..........
Old Aug 1, 2004 | 11:53 AM
87b16crx's Avatar
do you know if it is trannt oil or engine oil. you might have a blown rear mail seal also. since you did say it is coming from the inspection plate on the bottom of the tranny.
Old Aug 8, 2004 | 11:38 AM
ICeDoUt's Avatar
Default Re: (87b16crx)
problem found..... I took my tranny off, and inside the bell housing was pretty well covered in oil thick oil. And i found an inch crack in it, right above the shift linkage. I guess my differential got messed up.
Old Aug 9, 2004 | 02:41 PM
petsmart's Avatar
sorry to steal threads... but what is the rear mail seal.. sounds like thats what's happening to my girls civic...
thanks
HondaHeddie
Sep 29, 2006 07:40 PM
bossman032
Oct 9, 2003 09:24 PM
