Z rated Vs. V rated ?
Old Nov 27, 2001 | 09:32 PM
D-SPEED's Avatar
Default Z rated Vs. V rated ?
besides the mph rating, will a V rated be a harder compound than the Z rated ?
i ask because im looking to ditch my mugens for some GSR rims, and they only make the tire i want in 15'' V rated
Old Nov 27, 2001 | 09:41 PM
Crossett's Avatar
Default Re: Z rated Vs. V rated ? (D-SPEED)
I dont know, but I went 150 mph on Yok S306's. Those pieces of crap cant be anything more than V rated, so if you're worried about speed you should be fine.
Old Nov 28, 2001 | 12:25 AM
SjCiViCHB's Avatar
i think you can find out by just looking at the tread rating. if its lower then its softer. I had Nitto 450 V rated and the compound was harder then the Z rated Khumos i had on 15s. 195/50/15.
Old Nov 28, 2001 | 01:09 AM
martini's Avatar
yeah, the speed rating (v vs z, vs anything else) doesn't have a direct connection with the tires compound. you have to look at the threadwear rating for that.
Old Nov 28, 2001 | 05:06 AM
rtype11's Avatar
the biggest difference between Z and V has nothing to do with the rubber used, tread wear or traction rating, the carcass of a z tire has much more reinforcement and will keep its shape and remain strong under hard acceleration and high speed.
Z rated are very bad for drag race use if you have a radial, better find and H tire with decent traction rating and let some of the air out
Integra2316
Oct 15, 2011 12:26 PM
chahsiubow
Dec 19, 2006 12:23 PM
kratos24
Apr 17, 2006 03:07 PM
DC2IntegraTypeR
Mar 18, 2004 04:36 PM
99civic_exSB
Jul 11, 2002 11:15 AM
