sohc swap questions
Old Jul 31, 2004 | 10:20 AM
Mr.Death's Avatar
Default sohc swap questions
1st question: Will a 90 si flywheel and tranny bolt up to a d16z6 motor.
2nd question: Will a Fields unit activate vtec using a 90 crx si harness and 90 crx si ecu(obd0) or do I need the obd 1 ecu?
Thanks
Old Jul 31, 2004 | 11:18 AM
Bserieskllr's Avatar
1st question:yes you can bolt up a si tranny and flywheel on the z6.
2nd question not to sure but im sure you can if you run the vtec to the contoller...good luck and hope this helped.
rex89sir2
Jun 18, 2009 05:13 PM
civicshowracing65
May 24, 2004 05:25 PM
1SickHb
May 2, 2004 06:44 PM
