(5th gen) Where did you mount your HID ballasts and wires?
I'm installing an HID kit on my 94 Accord and everything is plug and play as far as the wiring goes but I'm wondering how and where you guys mounted the ballasts and wires. The engine bay seems pretty cramped and I don't see any place to put them.
Can you guys with HIDs post pics of where you mounted the ballasts and where you tucked the wires away? Thanks in advance.
on the driverside, there's plenty of room down there by the power steering fluid reservoir...you can either drill or find a pre existing hole...on the passenger side, i used the raised area creating the shock towers right behind where the original intake chamber would be...
on the drivers side like mentioned there should be a good amount of space, but for the drivers side im guessing you have abs since you dont have space... a few of my friends put em right under the abs lines but they had to drill + use double sided tape.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike813 »</TD></TR><TR><TD CLASS="quote">on the drivers side like mentioned there should be a good amount of space, but for the drivers side im guessing you have abs since you dont have space... a few of my friends put em right under the abs lines but they had to drill + use double sided tape.</TD></TR></TABLE>
Yeah I do have ABS and it still looks pretty cramped on the drivers side. Can you guys post pics of both sides of how you mounted them? Thanks in advance.
i dont have pics of his car, but there should be a spot right behind the steering fluid reserv. like nick h mentioned.
its a little hard to get to but its a perfect fit... my friends have the xenondepot kit.
well here you guys go... i dont have abs. get creative! hehe good luck btw if you have the h4 hids, you DEFINITELY should invest in some casper shields.
edit* forgot the pics
passenger's side
driver's side
passenger's side
driver's side
i got a 5th gen accord with philips HID, i mounted them in the same place as s.cali alan did .. i got pics, hit me up on AIM if you want to see the pictures ..... lata
I don't know if you guys can see that very well. I'll try to find better pics later. I mounted the ballast next to the abs. The other one is next to the battery, which cannot be seen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAccord96 »</TD></TR><TR><TD CLASS="quote">I don't know if you guys can see that very well. I'll try to find better pics later. I mounted the ballast next to the abs. The other one is next to the battery, which cannot be seen.
Do you have a closeup pic of how you mounted the ballast on the drivers side? I have an EX with ABS so my space is a bit cramped there.
</TD></TR></TABLE>Do you have a closeup pic of how you mounted the ballast on the drivers side? I have an EX with ABS so my space is a bit cramped there.
I used one of my girlfriend's hair rubber band thingies to secure the ballast there. It has been a little more than a year, and her hair band is still holding up perfectly. Sorry for the blurry pics. PM me if you want the hi-res ones.
JBBNJ609
Dec 19, 2003 02:58 PM
