Wiring changes for DOHC ZC swap into HF
Old Nov 27, 2001 | 07:53 PM
efeezie's Avatar
Default Wiring changes for DOHC ZC swap into HF
what wiring changes do I need to make if any?
Old Nov 27, 2001 | 07:59 PM
Chris_'s Avatar
Default Re: Wiring changes for DOHC ZC swap into HF (efeezie)
the changes that need to be made are you need to wire up a 2nd O2 sensor as well as a knock sensor and the wire for Vtec when I did mine I just got the sub-harness from Hasport here is the link http://www.hasport.com/wiring.htm
that will be the easiest route
Old Nov 27, 2001 | 08:22 PM
Cereal_Killer's Avatar
Default Re: Wiring changes for DOHC ZC swap into HF (crxconnection)
umm what?he's gpoing ZC not B16...which means no Knock sensor, and no 2nd O2 sensor. as far as HF to a ZC...i don't think there are any differences in wiring. as they are both Mpfi, if i am correct it should be plug and play swap. i think the only time you need to worry about wiring differnces is when you have a DX.
Old Nov 27, 2001 | 08:32 PM
FIVE.ONE.ZERO's Avatar
New User
Default Re: Wiring changes for DOHC ZC swap into HF (91efzc)
yup your rite.. plug and play.
hondaboy_1.8
Nov 19, 2007 07:35 PM
Spazius
23
Oct 15, 2007 02:50 PM
Tippyman
Apr 10, 2006 07:52 PM
brent_G
Feb 26, 2002 11:36 AM
