Tubular suspension parts/EG compatibility?
I've seen tubular suspension parts (I think lower control arm) offered in the Summit catalog (Comp. Engineering), but only for 92-00 Hondas/Acuras. Does anyone know of anything like this for EFs? Anyway it could be made to fit in my 91 CRX?
Thanks
Ben
Thanks
Ben
Those peices you refer to would be similar to the z10 radius rod kit. The kit you had mentioned will only work on a 92up civic or 94up teg. Z10 makes a kit for the EF's it goes for 550.00 Mine should be here sometime this week. It is supposed to eliminate wheel hop, and stiffen the frontend considerably. Check out http://www.z10eng.com and http://www.hybrid.honda-perf.org they have a good review on the kit.
The Z10 is only the crossmember and the radius rods, correct? The Comp. Engineering part was the lower control arm- stronger and a bit lighter than the stock piece.
Thanks
Ben
Thanks
Ben
chrisb
10
Jun 15, 2011 04:49 PM
regal1975
Apr 14, 2007 09:45 PM
