Spoon Caliper fitament questions...
I am looking at the Rota "Suckstreams" for a cheap, "I don't care they get fucked up," track rim.
I have CTR 5-lug on my EK and I soon will put on some Spoon calipers. (Thanks Mike) I know that the Spoon calipers fit the stock ITR/CTR 15" wheels, but I am not sure if they will fit with the Rota's.
The Rota Slipstream size is: 15x6.5, 40mm offset.
Will this fit with the Spoon caliper???
If not, do I need a wheel spacer? What size? And do I need them for all four wheels? Lastly, do I need extended wheels studs when using wheel spacers?
I have no idea about wheel spacers. Any suggestions on brand and where to get them?
TIA
[Modified by spoonek9, 7:26 PM 11/27/2001]
TIA
If I remember correctly (as far as Spoons SW388's) the 42mm offset wont fit but the 35mm will, So I would think that if the Slipstreams are close enough to the SW388 then you'll need a 5mm spacer
thanks mike....
I knew I could count on you...
BTW, are you supplying a J's Racing header for the great header test? I want to see how it performs since it is value priced.
Todd00
Nov 15, 2007 10:07 AM
