tps screw size
hey everyone, im about to adjust my tps. im removing the rivets and replacing them with screws. i was wondering if anybody knew what size screws should i use to replace them with? need help asap. thanks.
If you're worried about not being able to find the right size, i wouldnt worry about that, i believe the thread pitch is 1.25, Im not sure of the diameter, but I did this and i had the bolts that fit perfectly in my garage, when you drill off the rivits you will be able to unscrew the stud that is in there so you can take it to the hardware store with you if you need to
phthalo
Mar 20, 2006 10:03 AM
