94 civic suspention on 88 civic
Old Jul 30, 2004 | 11:37 AM
s2kkk's Avatar
Default 94 civic suspention on 88 civic
I swap out my 88 std civic suspention with 94 civic suspention with kybs in the back. I used the regular civic springs but i cut like 1 1/2 inchs cause i didnt have a spring compresser. Well there all on and my car sits high as hell like 5 inchs from top of tire to fender. Should i take more of the springs at least like 1 more inch.?? L
Old Jul 30, 2004 | 11:46 AM
tpr's Avatar
tpr
Default Re: 94 civic suspention on 88 civic (spoon.eg)
You are mixing generations of suspensions. I don't think the 94 will fit properly under an 88.
Old Jul 30, 2004 | 11:58 AM
4drEF's Avatar
Keyboard Humorist
Use a full coilover setup and it can be done.
I know for fact that the forks in the front are taller. That's probably what is making your car RANCHO style 4X4 - yeeeehaaaaaw!
The stock 5g shock is probably getting close to bottoming out so cutting the springs even more will be a bad idea.
You could just put in the the 88 forks and shocks to correct it.
I would think the rear suspension is sitting pretty close to the way it did with the 4g stuff.
Is it? I never experimented with 5g stuff back there so I don't know.
Old Jul 30, 2004 | 03:13 PM
s2kkk's Avatar
Default Re: 94 civic suspention on 88 civic (4drEF)
LOL it fits fine but i guess im going to have to cut them more. If they blow i got a xtra set.
bman511
Mar 29, 2005 08:05 PM
Hate
Apr 23, 2003 03:54 PM
phateless
Apr 11, 2003 11:30 AM
1hotintegra
Oct 30, 2002 06:23 PM
