Are 90-91 EX knuckles heavier than Si, DX knuckles?
I know that the brake setup (rotor + caliper + pads) will be heavier for the EX because the rotors and calipers are bigger than the Si. But what about the knuckle minus the rotor, caliper and pads?
Anyone know for sure?
Although they would seem heavier, they're probably not that much heavier if any. Are you having some shipped to you?
I couldn't imagine them being significantly different in weight like
that. The only difference is the hub and possibly the bearing.
FYI: you see how easy it is to go 5-lug ITR conversion by
machining the knuckles to accept the 5lug bearing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WWDTrackRacer »</TD></TR><TR><TD CLASS="quote">
The bearings are the same.
DeeEx Rex
Aug 28, 2013 06:34 AM
aalouie
13
Nov 6, 2008 05:36 PM
riceboyEFsi
Feb 1, 2003 04:09 PM
