Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Wilwood or OE brakes for daily driven/road course EF
Old Jul 30, 2004 | 06:42 AM
red civic standard's Avatar
Default Wilwood or OE brakes for daily driven/road course EF
The car is a '91 Civic with a b-series (~2100 pounds). I daily drive it in the summer only and do 4-5 road course events per year and am anticipating more events in years to come. I use 14" HX wheels for the street and 15" wheels on the track.
The current brake setup is as follows: 91 EX knuckles in the front (10.2 inch rotors) with Carbotech Panther+ pads and rear disc. The car stops great on the road course and never seems to fade and the setup is decent on the street (except for the major dusting).
The brake setup that I am considering is a fastbrakes Wilwood 4-pistion 10.2 inch rotor kit found here: http://www.fastbrakes.com/prod...F10-4 I would not be purchasing this brake kit for better stopping power, but rather for lower unsprung weight. The Wilwood calipers are about 6 pounds lighter than the OE ones I am currently using. I could also switch back from the EX knuckles to some Si knuckles (does anyone know if this saves weight?).
Is the weight savings worth the hassle? Should I just stick with my current setup?
Old Jul 30, 2004 | 06:51 AM
Driven's Avatar
Default Re: Wilwood or OE brakes for daily driven/road course EF (red civic standard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red civic standard &raquo;</TD></TR><TR><TD CLASS="quote"> The car stops great on the road course and never seems to fade and the setup is decent on the street (except for the major dusting)</TD></TR></TABLE>
hmmm, sounds like you're attempting to fix a problem you don't have.
Old Jul 30, 2004 | 07:08 AM
WWDTrackRacer's Avatar
New User
Default My experience
Well I have a 88 Std -- so I needed brakes. I could have gone OEM solution
which means EX knuckles + calipers (rebuilt?) + pads + rotors.
So I went w/ the FastBrakes Wilwood kit instead.
I have to run spacers (add weight) to clear the calipers. And I needed
to upgrade the MC/Booster.
It is lighter, I forgot how much more. Probably a couple pounds.
If you're strictly doing this for weight, I would probably just go with
lighter wheels first.
BTW, the pad selection can be a little difficult and they can be more
expensive than vanilla EX/Integra pads.
Old Jul 30, 2004 | 07:11 AM
Default Re: My experience (WWDTrackRacer)
Wilwood has a 10.2 inch kit and an 11.0 inch kit. I am interested in the 10.2 inch one so that I don't have to get bigger wheels or run a spacer.
I already have the EX 15/16" master cylinder and lightweight wheels.
Old Jul 30, 2004 | 07:17 AM
Solracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red civic standard &raquo;</TD></TR><TR><TD CLASS="quote"> The car stops great on the road course and never seems to fade and the setup is decent on the street (except for the major dusting).
Is the weight savings worth the hassle? </TD></TR></TABLE>
If your brakes are not fading why upgrade? Besides depending on what you plan on doing with the car, putting that willwod kit could not you out of a class you might want to run into a class where you need speed much dollars to compete. What Tracks do you road race on?
Old Jul 30, 2004 | 07:30 AM
Default Re: Wilwood or OE brakes for daily driven/road course EF (Solracer)
I race at Gingerman Raceway in South Haven, Michigan.
I think I have already put myself out of any stockish class with my motor swap.
Another consideration is cost of pads. Panther+ pads for my current setup are $119 a set and the Wilwood pads are around $60.
Old Jul 30, 2004 | 07:59 AM
Safir's Avatar
Wilwoods are not particularly happy in a DD environment.
but they do perform well at gman
Old Jul 30, 2004 | 08:46 AM
New User
Default more info
Umm... I have the 10.2 Wilwood kit and I have to run a 15mm spacer
with a 14" wheel or at least 7mm spacer on 15 wheel. BTW,
you will need to add longer wheel studs if you run spacers.
Add more weight.
Lightweight wheels are under 11 lbs IMO.
DTMotorsports's Avatar
Default Re: Wilwood or OE brakes for daily driven/road course EF (Safir)
The Wilwood kits are considerably lighter. Also pads are a lot cheaper than Hawks or Porterfield. Will you be switching to 15's for both street and track?
a little off topic, but for those of you running 15's, I have talked to wilwood and they have a kit which will work. I have all the dimensions and this would be straight from wilwood, not the fastbrake kits. Thought I would put this out, since a lot of people were asking about a kit for 15s
Old Jul 30, 2004 | 08:55 AM
Default Re: Wilwood or OE brakes for daily driven/road course EF (DTMotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DTMotorsports &raquo;</TD></TR><TR><TD CLASS="quote">Will you be switching to 15's for both street and track?</TD></TR></TABLE>
No....I use HX wheels on the street and I am pretty stuck on keeping them. I will be using 15s at the track.
How much lighter are the Wilwood kits? How much would this help my lap times?
Old Jul 30, 2004 | 12:02 PM
rex_boy's Avatar
a little off topic, but for those of you running 15's, I have talked to wilwood and they have a kit which will work. I have all the dimensions and this would be straight from wilwood, not the fastbrake kits. Thought I would put this out, since a lot of people were asking about a kit for 15s</TD></TR></TABLE>
Do you have more detail on this (kit part #)? How much does it cost?
Where do you get pads do they have to be special order or are they off another model car?
What size rotors and where would you get those when they need replaced? How much do new rotors cost?
Thanks
M3THTICAL(EF)
Suspension & Brakes
Mar 4, 2015 07:41 AM
neofreak
Nov 22, 2010 12:08 PM
neofreak
Nov 21, 2010 10:24 PM
Driven
29
Oct 21, 2003 06:59 AM
red civic standard
14
May 2, 2003 08:35 PM
