Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
which motor mount is most important?
Old Jul 30, 2004 | 05:43 AM
tom91ita's Avatar
Banned
Default which motor mount is most important?
my front motor mount on my '88 crx si and 90 civic si is badly cracked and all but broken. oem and ~15 years and 191,000 miles, etc.
for the budget minded, i am going to replace this but which other mount should be replaced next for ita and autocrossing?
Old Jul 30, 2004 | 05:55 AM
CRX Lee's Avatar
Default Re: which motor mount is most important? (tom91ita)
I'd think the front one to be the least important with the driver's side probably most important and rear or passemger side next. The obvious answer is all of them.
Old Jul 30, 2004 | 07:59 AM
tom91ita's Avatar
Banned
Default Re: which motor mount is most important? (CRX Lee)
when thinking about the motor "wind-up" during acceleration, it would seem that the front & back take most of the abuse. why the driver side?
btw lee, i may start looking for the konis for my 85 si after all since i don't have a complete set of tokicos any more!
Old Jul 30, 2004 | 08:19 AM
CRX Lee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tom91ita &raquo;</TD></TR><TR><TD CLASS="quote">when thinking about the motor "wind-up" during acceleration, it would seem that the front & back take most of the abuse. why the driver side?
I know that front and rear are of great importance on cars with torque (not something CRXs have to worry about). My Omni GLH Turbo wore fronts at a faster rate. I figured the driver and passenger side was under all of the cornering load holding the drivetrain in the shell and the car would probably be cornering harder than it accels. I figured the driver's side might wear quicker because of size and general design shape.
btw lee, i may start looking for the konis for my 85 si after all since i don't have a complete set of tokicos any more!</TD></TR></TABLE>
They are going to be getting harder to find unless I can have more made which is an outside chance at best. My stepdad's Civic is sitting on a fresh custom set but he isn't ready to give up on the car yet even though he doesn;t use it..
Old Jul 30, 2004 | 12:06 PM
rex_boy's Avatar
With the hasport kit and engine swap I haven't used a front 4 years now. althought the poly kit makes them a lot sturdier.
Old Aug 1, 2004 | 10:28 PM
turbohappy's Avatar
Just fill them all with 3M windo-weld and chopped up cutting board. That's what I did on my 190k CRX and you can't move my engine if you try
Old Aug 1, 2004 | 11:06 PM
MAD ITR 55's Avatar
Default Re: which motor mount is most important? (turbohappy)
All of them
Old Aug 2, 2004 | 08:57 AM
Bones Barry's Avatar
Default Re: which motor mount is most important? (MAD ITR 55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAD ITR 55 &raquo;</TD></TR><TR><TD CLASS="quote">All of them </TD></TR></TABLE>
Yeah I don't think you can say one is less important than another. They all serve a purpose and are all in place for a reason.
Old Aug 2, 2004 | 09:13 AM
chad's Avatar
Moderator
the most important is the rear tranny bracket/mount!!
Old Aug 2, 2004 | 09:48 AM
Team 4's Avatar
Default Re: which motor mount is most important? (chad)
I've had very good luck with the Energy Poly inserts. Cheap too, but they do their job.
Old Aug 2, 2004 | 11:38 AM
tom91ita's Avatar
Banned
For ITA and Stock autocrossing, unmodified stock bushings/mounts are all that i am allowed. I'm ordering front ones now (ITA '88 Si and H-Stock '90 Civic Si) and will buy more based on a detailed inspection of the others. The front ones appear to be the closest to failure due to deep cracks in the rubber.
raider099
Dec 13, 2007 12:38 PM
D-meet07
Jul 15, 2007 12:23 PM
ShadyBAB
Dec 29, 2005 04:19 PM
RacerSi
Nov 17, 2003 02:42 PM
88' CRX ZC
Jun 25, 2002 03:13 PM
