radiator fan not working...help!!!
hello all...i dont believe my radiator fan is working. i dont hear it turn on and im running hotter than usual. im also getting that splotchiness on my head from running to hot. b18c1 swap in an ek hb. apex'i head. did i blow a fuse? wiring? any input would be great. this is my first vtec motor so im still new at this. what can i do to fix it? it worked fine before.
Modified by ekfighter at 1:32 AM 7/30/2004
I believe you need a BIGGER RADIATOR for your HB if your have a b18c motor. thats if you didnt change your stock radiator. My brother swapped a b20 in his 92 HB and he was overheating even though his radiator fan was working and stuff. He put in a dual core radiator and now his heat gauge just sits at middle, no overheating. Thats if u didnt do it already.
if your car has over heated before you probably just burnt the fan switch it goes on the left side of the block you can buy it at your local auto part store.My fan just stop work like that too and thats what it was for me
fuse isnt blown....havent checked fan relay yet. thanks. How can i check if relay is bad besides just replacing it? Oh..and where would the fan switch be on the block?
Modified by ekfighter at 10:59 PM 7/30/2004
