STR fuel rail help??
Old Jul 29, 2004 | 10:20 PM
Jdmglenn's Avatar
Default STR fuel rail help??
hey guys i gots a 96 gsr. and i recently got an str fuel rail. Question is how does the fuel line from the filter connect to the rail? all the rail has is threds and no male piece like the stock fuel rail.
and also the spot where the fuel regulator bolts to is the same just threds, so how does it work??
any help is appreciated, thanks
Old Jul 30, 2004 | 05:39 AM
KoRE's Avatar
Default Re: STR fuel rail help?? (JdmGlenn)
it should have came with a fitting to add to the end of the rail and for the FPR you need to drill the hole out.
Old Jul 30, 2004 | 06:04 AM
pb16b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmGlenn &raquo;</TD></TR><TR><TD CLASS="quote">hey guys i gots a 96 gsr. and i recently got an str fuel rail. Question is how does the fuel line from the filter connect to the rail? all the rail has is threds and no male piece like the stock fuel rail.
any help is appreciated, thanks</TD></TR></TABLE>
it should have came with a banjo fitting with an acorn nut that bolts up your factory fuel line... i can get you those fittings if you need them.
the fuel regulator holes are there and threaded however, the hole for the fuel pressure regulator is blocked off. it's blocked off in case the buyer wishes to use an external fuel pressure regulator off the end of the fuel rail. if you wish to use the factory fuel pressure regulator, you have to drill out the blocked hole.
Old Oct 8, 2004 | 04:49 PM
philly-O's Avatar
Default Re: STR fuel rail help?? (pb16b)
the str rail i just got has the same blocked holes, do i drill them out as big as possible not damaging the threads? also the acorn nut doesnt thread onto the banjo fitting.
lickety_britches
Apr 22, 2009 06:19 PM
johnwohl
Feb 10, 2008 11:07 AM
HpRevolution
May 23, 2007 09:42 AM
