AEM wide band A/F gauge?
Old Jul 29, 2004 | 09:41 PM
iheartboost's Avatar
Default AEM wide band A/F gauge?
I wanted to know if the AEM wide band A/F gauge is accurate? I heard good things but am not sure. Also what is the most lean A/F ratio that would be safe with a turbo D!6y8...maybe 13-13.5?
Old Jul 29, 2004 | 10:33 PM
suspendedHatch's Avatar
Default Re: AEM wide band A/F gauge? (iheartboost)
It's accurate, and it's the best thing on the market.
You're too general about your setup for anyone to make a recommendation. Compression ratio? Octane? Boost psi? With a normal low comp, mild boost setup, you should be running stoich 14.7 except under heavy load. 13 is rich. 16 is lean, is that what you meant to ask?
Old Jul 29, 2004 | 10:34 PM
dohcMONSTER's Avatar
Default Re: AEM wide band A/F gauge? (shaundrake)
he's running the edelbrock kit @6-7 psi i forget....hey ryan nice name, this is Anthony BTW
Old Jul 29, 2004 | 10:39 PM
hondaeg8's Avatar
Default Re: AEM wide band A/F gauge? (sohcMONSTER)
what do these widebands go for? price wise?
Old Jul 29, 2004 | 11:01 PM
Yeah, the edelbrock kit, stock d16y8 compression, 91 octane, 6-7 psi, but I want to turn it up to 10 psi, I just wanted to know what A/F ratio would be as lean as I should run with this set up. sorry for being so vague. The gauge goes for around $450
RealStreet
Jul 3, 2012 12:50 PM
VTECth1s
May 10, 2006 08:34 PM
escapist13
May 3, 2002 08:54 AM
escapist13
May 2, 2002 07:39 PM
