Please HELP!! AC problems!!!! i'm a newbie
Old Jul 29, 2004 | 06:41 PM
mushu315's Avatar
Default Please HELP!! AC problems!!!! i'm a newbie
before my AC was acting up. it stopped getting cold and when i idle my engine will rev by itself automatically.
i got tips from people here to get a DIY refrigerant re-charge kits with a gauge.
I tried running it but when i put on the gauge, it turns out that it was in the "Red - Danger" Zone. how do i release some of the pressure?
my engine was running and my AC was on max when i was testing it (like what the instructional movie said)
please help!!! it's hot out.
Old Jul 29, 2004 | 06:47 PM
hatchling37's Avatar
Default Re: Please HELP!! AC problems!!!! i'm a newbie (mushu315)
Take that **** to a shop. If you're not qualified to work on your refrigerant, take it somewhere if you don't know what you're doing. If you release that ****, that's way illegal, and not to mention harmful to you and the environment.
Old Jul 29, 2004 | 07:03 PM
HondaHemp's Avatar
Default Re: Please HELP!! AC problems!!!! i'm a newbie (HTechBB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HTechBB &raquo;</TD></TR><TR><TD CLASS="quote">First of all by doing this yourself your going to break a federal law. Releasing that r12 or r134a depending on the year of your vehicle into the air is considered bad by the EPA. And they will give a $5000.00 fine if caught. Now, with that said, I will not tell you how, but just let you know that when a line has pressure there's always way to relieve it. See those color caps on your Hi(H) and Low(L) sides of your a/c. They come off to reveil, a bleeder, kinda like a tire valve stem. Nuff said. Good luck bro.</TD></TR></TABLE>
Well said my man!!
Old Jul 29, 2004 | 07:53 PM
honda9369's Avatar
r12 is deadly and in most states its hard to find. the problem that u r having is that your tryin to recharge your ac with the ac on. u dont even need to have the engine running. if you can afford to go to a shop i would do so.and have them evac and recharge your system. might take an hour depending on the machine
Old Jul 30, 2004 | 02:51 AM
mushu315's Avatar
thanks guys
about how much will it cost?
Old Jul 30, 2004 | 03:04 AM
mustninty's Avatar
I'm thinking since your AC system is full or overfilled that the shop would only charge for evacing the 134a maybe run a leak test and refill it to the proper level. So I dont htink they would charge for the freon, I know that when I managed a jiffy lube we would not have but it all depends how honest your shop is. I',m thinking a $100.
xxjokoxx
Aug 23, 2010 12:51 AM
Civic Racer X 7
22
May 6, 2007 01:31 PM
silverrat
Jul 19, 2005 11:02 AM
wilsel
Sep 2, 2004 01:19 PM
m_mathers_69
Jun 5, 2004 11:08 AM
