All motor help
Old Jul 29, 2004 | 04:44 PM
truespeed's Avatar
Default All motor help
I've got this set up: b18c block, b16a head, pr-3 pistons, port and polish, three angle valve job, total seal rings, spoon head gasket (2 layer) 11.74:1 Cr, skunk2 intake manifold, 62mm bored tb, Itr cams, kms dual valve springs, titanium retainers, mugen ecu vtec @4500 (disabled o2 sensor), msd ingnition and coil, airmass headers. Dynoed at 170 whp, 123 ftlbs torque.
WTF!!! What am I doing wrong here? Do I need a cam gears or what else?
Tech help please!!! Trying to get to 200+ hp.
Old Jul 29, 2004 | 05:16 PM
self.one's Avatar
first off, your tb is way too small....a 70mm should get you started where you need to go, of course port matching your manifold for your new tb would help too.... then i would switch out your cams for something a bit wilder, get some sprockets..... then a better header..... obtw, what exhaust are you running? should be no smaller than 2.5"s, but don't go 3"..... finally get the damn thang tuned and you should be well on your way.... hope this helps....
eddie...
Old Jul 30, 2004 | 04:36 AM
truespeed's Avatar
Does it matter what brad name header I get? I hear DC JDM is pretty good. But I've seen generic headers at ebay with the 2.5" collector 4-1 style for under a hundred. I also notice black smoke comming out during higher rpm's around 8000 rpm and up.
Old Jul 30, 2004 | 05:08 AM
87b16crx's Avatar
a little bit of black smoke is ok but if your blowing alot, you are running to rich and the fuel needs to be turned down. that can also hinder you hp if you have to much fuel
Old Jul 30, 2004 | 07:20 AM
AngelR's Avatar
Default Re: (self.one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by self.one &raquo;</TD></TR><TR><TD CLASS="quote">first off, your tb is way too small....a 70mm should get you started where you need to go, of course port matching your manifold for your new tb would help too.... then i would switch out your cams for something a bit wilder, get some sprockets..... then a better header..... obtw, what exhaust are you running? should be no smaller than 2.5"s, but don't go 3"..... finally get the damn thang tuned and you should be well on your way.... hope this helps....
eddie...</TD></TR></TABLE>
Ken, doesn't this stuff sound familiar? Do as he and I say, and with the basic stuff that you already have in place the car should improve greatly.
Old Jul 30, 2004 | 12:03 PM
self.one's Avatar
just trying to help him out where i can....
Old Jul 30, 2004 | 07:14 PM
truespeed's Avatar
Angel just trying to get a second opinion. After all you can never know too much right? By the way I gave your number to a couple of people, hopefully I can get a discount on tunning after some refferals. But no disrespect, you do know you ****.
Old Jul 31, 2004 | 12:55 PM
AngelR's Avatar
Default Re: (truespeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by truespeed &raquo;</TD></TR><TR><TD CLASS="quote">Angel just trying to get a second opinion. After all you can never know too much right? By the way I gave your number to a couple of people, hopefully I can get a discount on tunning after some refferals. But no disrespect, you do know you ****. </TD></TR></TABLE>
No, I wasn't insinuating that you doubted me.... just poking fun Yeah whenever your ready or if you need any advice just give me a ring.
Old Jul 31, 2004 | 01:07 PM
eyeamvic's Avatar
Tuning.
Old Jul 31, 2004 | 05:30 PM
AngelR's Avatar
Default Re: (eyeamvic)
We went over that as well..... unfortunately, the only adjustable item he has is timing and we did pick up a little by setting that correctly. He needs a better header, cam gears, 2.5 " exhaust, and something to adjust fuel at a min (ideally something to adjust both fuel and timing tables). He had come to me just to baseline and get some idea where he was and where he should go from this point.
stupid fast
11
Mar 25, 2015 07:45 AM
green_eg_hatch
Jan 23, 2010 04:21 PM
seldon
Nov 5, 2009 09:51 AM
Captain Save-a-Hoe
14
Oct 27, 2002 02:25 PM
SiBirdie
Oct 13, 2001 03:31 PM
