engine rubbing on the hood
Old Jul 29, 2004 | 03:37 PM
untitledsn41's Avatar
Default engine rubbing on the hood
ok, i finshed up my swap, runs fine cept vtec(not hooked up yet) and my hood clears by half an inch. and when i rev it up and the motor mooves a little bit it hits the hood. WHAT DO I DO???
Old Jul 29, 2004 | 03:43 PM
JDMisGOOD's Avatar
Default Re: engine rubbing on the hood (untitledsn41)
are all of your mounts hooked up properly?>
Old Jul 29, 2004 | 03:44 PM
Gesundheit's Avatar
get motor mount inserts
Default Re: engine rubbing on the hood (JDMisGOOD)
yeah! why could this be happening. does this happen to anyone else??!?!?
mount inserts...??? explain please
Old Jul 29, 2004 | 03:47 PM
antiJDM's Avatar
https://honda-tech.com/zerothread?id=713941
simply done by searching "mount inserts"
Old Jul 29, 2004 | 03:50 PM
Marauder's Avatar
Default Re: (2thousandcivic)
Inserts are stiffer and doesn't allow the engine to rock over.
Either that or just cut out the hood support structure!
i searched right after i posted and found that too. how difficult is it to install them..? do i have to pull the motor?
Old Jul 29, 2004 | 03:56 PM
antiJDM's Avatar
i did mine when my motor was pulled, go to http://www.homemadeturbo.com in one of the tech sections there is a diy mount inserts
Archidictus's Avatar
Unceasing Measure
Default Re: (untitledsn41)
A B18C should never hit the hood when in an EG chassis unless you A.) failed to install all the mounts, B.) have a broken mount or two, C.) jury-rigged something incorrectly or D.) have your hood sitting too low.
If you've done everything mentioned correctly you may want to look into one of those "dampers" that you mount to your engine and the shock tower...they're specifically designed to absorb the forward toqueing of an engine and transfer that lost power and motion to the ground.
Good luck.
Old Jul 29, 2004 | 03:58 PM
wizzards581's Avatar
i got a driver mount insert for sale... brand new.. b18c~
Old Jul 29, 2004 | 04:01 PM
b00steds2k's Avatar
hey just add washers and a bigger bolt to the four that attach the hood it will be a little bit higher but fixes the problem
Old Jul 29, 2004 | 04:03 PM
antiJDM's Avatar
sorry...Off Topic
not to burst your bubble civicsleepa...but 15" rotas go for under 500...new with tires in some places, at least thats what i bought mine for
Old Jul 29, 2004 | 04:51 PM
dantastic's Avatar
do you have a factory/oem hood? i've heard of aftermarket hoods having problems with b-swaps
Old Jul 29, 2004 | 07:35 PM
gabhatch's Avatar
put a couple washers under the motor mounts to shim motor down
dohdoh420
Sep 4, 2006 10:43 PM
JDM00SI
Nov 15, 2005 06:46 AM
MrCivic98
Jun 5, 2005 09:26 PM
mc
Oct 19, 2004 08:22 AM
nasteboyii
Jan 28, 2004 06:14 PM
