Could I use Comptech endlinks on a 23mm OEM JDM ITR Rear sway bar?
Old Jul 29, 2004 | 02:00 PM
EL-Driver's Avatar
Default Could I use Comptech endlinks on a 23mm OEM JDM ITR Rear sway bar?
Need an answer ASAP..
wonderin if I could use Comptech endlinks which are designed for a 22mm rear sway on
a 23mm JDM ITR rear sway bar?
got a good deal on them...so wonderin if I can use them or not?
Modified by EL-Driver at 11:46 PM 7/29/2004
Old Jul 29, 2004 | 04:29 PM
cheezthis's Avatar
Default Re: Could I use Comptech endlinks on a 23mm OEM JDM ITR Rear sway bar? (EL-Driver)
Nope...at least I couldn't. The comptech endlinks go through the bar, where as the oem bar has the endlinks go over the bar, if that makes sense. It's too bad too, the comptech endlinks are better.
Old Jul 29, 2004 | 06:53 PM
Comp97GSR's Avatar
Default Re: Could I use Comptech endlinks on a 23mm OEM JDM ITR Rear sway bar? (cheezthis)
This is correct...... except I don't really care for the Comptech links.
Have you replaced yours or adjusted them.... BTW I have the 1st gen swaybar.
Dr0d23
Acura TSX
May 26, 2008 10:29 PM
kcjohnnyboy
Suspension & Brakes
30
Aug 27, 2007 01:10 PM
216.226.142.95:27016
Suspension & Brakes
Jun 21, 2005 01:41 PM
Seedc2
Jun 13, 2003 12:58 AM
