How u guys get ur R smoged??
Im buying a 2000 integra type r, it have aem cold air intake, dc header, spoon exhaust, spoon cams, spoon cam gear, flywheel, clutch. the question is can i pass the smog with all these parts in it? how u guys passed ur R with mods?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedLineHatchSi »</TD></TR><TR><TD CLASS="quote">i thought aem intake, and dc header are street legal to do smog check</TD></TR></TABLE> those maybe smog legal but i doubt the cams are!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Spoon cams and cam gears = will affect smog results. </TD></TR></TABLE>
they will affect the results, only the emissions portion. the smog tech won't be able to see the cams, but the cam gears if you have a cut valve cover.
Which dc header? does it have a carb#?
The aem unit should be fine, those have carb#.
Cat back exhaust should be fine, those aren't regulated by CARB.
Flywheel/clutch have nothing to do with the emissions devices.
Just make sure you get a working cat with the car, and all the stock parts too. Mainly the header, stock cat, and stock airbox. stock ecu too.
You can only be failed by what they see, smell and read.
edit, btw, i don't know if that setup will pass the sniffer. but if the valve cover is uncut, and the dc has CARB #'s, then your only worries would be the sniffer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedLineHatchSi »</TD></TR><TR><TD CLASS="quote">how u guys passed ur R with mods?</TD></TR></TABLE>
Mn u sl ad fds, w cr.
Speak English! This isn't a chat room for eight-year old boys!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swtxaznrac3r »</TD></TR><TR><TD CLASS="quote">my friend takes his to a gas station. they don't even look at tha car, just slap stickers on</TD></TR></TABLE>
<~~Looks out the window at his 87' CRX oil burner and smiles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedLineHatchSi »</TD></TR><TR><TD CLASS="quote"> how u guys passed ur R with mods?</TD></TR></TABLE>
Honestly, many of us gave up and moved somewhere that it's not illegal (by local and state law) or at least not regulated.
If the car you're talking about buying is due for a smog test soon, then make the owner do it before you buy it.
What kind of computer is on this car?
Damn you. Damn all of you non-smog regulated people. Damn all of you's!
At nights, when I dream, I see a city with beaches, hot women, and no smog laws, and little bbasso's running around. :sigh: If only I could sleep for eternity...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">Smog check??? haha!
no need for that these days...
wat do u mean ??
</TD></TR></TABLE>wat do u mean ??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton »</TD></TR><TR><TD CLASS="quote">
well, its not due for a smog test,
its has a spoon ecu
its has a spoon ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKology »</TD></TR><TR><TD CLASS="quote">Damn you. Damn all of you non-smog regulated people. Damn all of you's!
you dream about bbasso???????? dunno whether i should barf or try to hold it in
</TD></TR></TABLE>you dream about bbasso???????? dunno whether i should barf or try to hold it in
its has a spoon ecu</TD></TR></TABLE>
Ahh. I was hoping you had a tunable ECU.
With the stock Spoon ECU, you will have to resort to finding someone w/a lot of knowledge and playing with the spark advance and valve timing until you know it'll pass.
It will probably work, but it might not...and it will definitely be troublesome.
