Part Number or Size for this Part on the Throttle Body IDLE
One day, I was adjusting my throttle stop screw, but I forgot to tighten my nut to keep the adjustment screw from coming out.
I call Honda dealer, and they have no idea what I'm talking about. I even asked them to bring it up on the screen, but they don't have that angle of the throttle body.
The nut came out, and the screw fell out of my car while driving. Now my car doesn't idle. It bascially dies! My quick getto fix was to disconnect one of the vacumm lines, so now it idles at 1500RPM.
Where can I get this part? Or what size it is?
Modified by All-Motor H22A at 7:47 AM 8/2/2004
Bad luck. I'd say double bad luck
First one: it's an integral part of TB. You must search for an used TB to get that screw.
Second one: this screw is set by the factory and all manuals say not to touch it. If you find this screw you will have to look how much it is screwed in to get more less the same .
Yea try a junkyard. You can also try JDM concepts in Vista since you are in San Diego. They should have some used t/b's in stock. 760 806-9489
All it is, it's a screw. All I need is the pitch and size, and I'll be able to put it in. Anyone know the measurements of it?
It requires a 3.5mm allen wrench to adjust it.
