Spark Plugs for an 11:1 ls motor.
I just finished building up my b18a with p30 pistons. It should be around 11:1 compression and I was wondering what kind of spark plugs I need to use with this set up. I have read a couple of searches and most are about vtec heads. I dont know if that changes anything or not, but any help is appreciated.
I'd go with a heat range of 7. 6 is a stock B16/B18 heat range, with the added compression over stock go with 7s. I use NGK BKR7E-11s.. only $1.89 or so per plug.
just wondering what the benifits are of using 7's .....
I'm at 11.4:1(B17/ctr) and I'm using BKR6E-11 with no problems..... am I doing damage to my engine by using these plugs or am I losing power because of them.....pls enlighten me.... thanks..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec101 »</TD></TR><TR><TD CLASS="quote">im using autolites from autozone </TD></TR></TABLE>
autolite plugs for imports aren't as good as they are for domestics... so
