Car won't start- Need help asap- smell lots of fuel
Old Jul 29, 2004 | 11:58 AM
mrod006's Avatar
Default Car won't start- Need help asap- smell lots of fuel
what's up guys. my car threw a cel today. it is cranking over but it won't start. i have a greddy sohc turbo kit with blue box. i do smell a lot of fuel. what could the possible problem be b/c this is my daily driver. any help is appreciated.
Old Jul 29, 2004 | 05:34 PM
mrod006's Avatar
Default Re: Car won't start- Need help asap- smell lots of fuel (mrod006)
anybody? it's a 00 civic ex if that helps.
Old Jul 30, 2004 | 08:11 AM
mrod006's Avatar
this might help too. the cel blinks once and stays on. anybody?
Old Jul 30, 2004 | 09:52 AM
bruthaboost's Avatar
Back to basics: There are three things necessary for ignition -say it with me
compression
fuel
spark.
You have one, fuel.
Most likely you have compression.
Check your spark. With a spare plug, plure a spark plug wire, throw in that spare plug, ground it and have a friend crank the engine. No sparkie, look to your ignition and all elements involved (ie, grounding points, coid, ICM).
Good luck.
Old Jul 30, 2004 | 03:09 PM
mrod006's Avatar
Default Re: Car won't start- Need help asap- smell lots of fuel (bruthaboost)
cool. i will look into that. thanks. anybody else?
Old Jul 30, 2004 | 04:52 PM
DXDOHCVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruthaboost &raquo;</TD></TR><TR><TD CLASS="quote">You have one, fuel.
Check your spark. Good luck.</TD></TR></TABLE>
Old Jul 30, 2004 | 08:05 PM
mrod006's Avatar
Default Re: Car won't start- Need help asap- smell lots of fuel (DXDOHCVTEC)
ok. i checked som things today. i took out the plugs and cranked it over. a lot of fuel kept coming out. i took out the fuse for the fuel pump and checked for spark and there was no spark. i am completely lost right now. would the o2 sensor be a factor in this?
also, could i have messed up the ecu?
Old Jul 30, 2004 | 08:22 PM
vtekstorm's Avatar
check the wiring to the emanage make sure everything is correct. and get a can of compressed air and take the plugs out and shoot air in the cylinders so u can get sum of the fuel out cuz now wit that much fuel in the engine your flooding it out, and youll have more trouble getting it started
Old Jul 30, 2004 | 09:50 PM
mrod006's Avatar
Default Re: Car won't start- Need help asap- smell lots of fuel (vtekstorm)
right now, i have the plugs out of the car and it's airing out now. i have to check the blue box again for missing connections. thanks for the info. anything else i need to check?
Old Jul 30, 2004 | 11:21 PM
I'm not familiar with the blue box, however check for battery voltage on your ecu wire going to your ignition controll module.
Old Jul 31, 2004 | 10:30 AM
mrod006's Avatar
i don't know if this makes any difference but i tuned the ignition to on and there was no cel. this is without the fuel pump fuse. when i put it back in, i got a cel. would this tell me anything?
Old Aug 2, 2004 | 06:22 PM
mrod006's Avatar
ok. i replaced the coil and i reset the ecu. the cel is gone but it still won't start. i used the old spark plugs that got flooded. could it be that i need some new plugs and it would start?
Old Aug 2, 2004 | 06:45 PM
Check the voltage going to your ICM. Open up the distributor, and put a multimeter/test light on the yellow/green wire with the key turned to ignition. You should get battery voltage. Anything less, you have a prob and yes the car can start with less than battery voltage (but you'll encounter more probs done the line).
Most likely you won't have battery voltage. I'm not sure if the blue box cuts into the ignition, but I'm betting it does. Look there.
Old Aug 2, 2004 | 07:39 PM
Kamin's Avatar
guys
start with the basics.
distributor cap, rotor.
try replacing them. they are wear items and should be replaced reguarly.
Old Aug 2, 2004 | 08:37 PM
Default Re: Car won't start- Need help asap- smell lots of fuel (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">guys
try replacing them. they are wear items and should be replaced reguarly.</TD></TR></TABLE>
Yeah, that's what I said initially. See my first post
Old Aug 2, 2004 | 08:38 PM
accordracer789's Avatar
vacumm leak?
Old Aug 3, 2004 | 05:29 PM
mrod006's Avatar
Default Re: Car won't start- Need help asap- smell lots of fuel (accordracer789)
update
i tried checking for spark and one orange spark came out of it. that's all. i'm guessing that i should buy a new dizzy. Could the ecu have fried also? i also replace the spark plugs.
Old Aug 3, 2004 | 05:35 PM
Wafler's Avatar
Hondas have problems with the igniter unit in the dizzy occasionally. If it is dead - no spark. Happened to me.
Old Aug 3, 2004 | 05:56 PM
mrod006's Avatar
Default Re: Car won't start- Need help asap- smell lots of fuel (Wafler)
i'm pretty sure it's the ignitor but i can buy a new dizzy for the price of the ignitor. unless the ignitor is cheaper than what i think it is.
Old Aug 4, 2004 | 07:27 PM
mrod006's Avatar
Update:
the car started today now it idles funny. i checked the code and its a p0107 map sensor low voltage. does this mean that i need another one and where is it located? the idle fluctuates. is this normal when there is a map sensor problem? also, the greddy blue box crapped out. that's why the car wouldn't start.
fcbdolphinz
Sep 8, 2009 03:54 PM
rhd_ef8
May 11, 2007 03:29 PM
EckoTech
Oct 30, 2004 01:25 PM
1stealthls
Oct 24, 2004 12:25 AM
temp
15
Jul 6, 2004 08:07 PM
