difference in a SI head and GSR head
trying to see the difference between SI head and GSR head...
i know the sotck GSR has dual valve springs on the exhaust side, wondering if the stock SI head had dual valves springs an all? and also wondering the what RPM both stock head can handle. I know the GSR head can handle 7800-8200, do anyone know what an SI can handle? thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lo0nY »</TD></TR><TR><TD CLASS="quote">trying to see the difference between SI head and GSR head...
i don't know anything too technical, but i also think there maybe a valve angle differnce as well.
someone with more technical experience chime in though
Si motors rev to 8k stock and I have read of people running them to 8500-9000 or so on stock springs. Only to 9000 if it is done very rarely but its still pushing it. Anything more than that and your going to end up floating valves. Personally I would not go over 8500.
it isnt recommended to go to 9k on any b series head with stock valvetrain, unless you're ready to fix some parts.....
physically the 2 heads are different-- the bolt patterns for the intake manifold are different from the two, as well as the ports and bowls of the head... an itr head is basically a b16 or Si head with work done to it (mild p&p, valvetrain) from the factory.... hope this helps...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by self.one »</TD></TR><TR><TD CLASS="quote">it isnt recommended to go to 9k on any b series head with stock valvetrain, unless you're ready to fix some parts.....
physically the 2 heads are different-- the bolt patterns for the intake manifold are different from the two, as well as the ports and bowls of the head... an itr head is basically a b16 or Si head with work done to it (mild p&p, valvetrain) from the factory.... hope this helps...</TD></TR></TABLE>
you might have more luck in the all-motor forum
you're also right about the itr matching (ie: poor-man's R is a b16 head with b18 shortblock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art In Motion »</TD></TR><TR><TD CLASS="quote">b16 flows better...gsr has higher comp </TD></TR></TABLE>
you can rev a stock gsr or si head to 9k no problem only the itr and ctr have dual vlave springs on exhaust si and gsr hove them only only on intake the heads flow rate are close really close the gsr can flow just as much as a si head will they are designed different because of the intake manifold were designed different a gsr head can be reshaped to that of an si head, its just a preference.
the GSR heads have a partial combustion chamber (not the correct terminology). the combution chamber stops after the valves and becomes flat, (_) like that. while a b16 head has a "full"combustion chamber that extends all of the bore. like this O.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjay8604 »</TD></TR><TR><TD CLASS="quote">the GSR heads have a partial combustion chamber (not the correct terminology). the combution chamber stops after the valves and becomes flat, (_) like that. while a b16 head has a "full"combustion chamber that extends all of the bore. like this O. </TD></TR></TABLE>
gsr = pentroof style chambers.
after much research, that is the only thing they have over b16 heads.
you can also weld the b16 chambers and reshape to pentroof style...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL »</TD></TR><TR><TD CLASS="quote">
actually the floor of the intake port on a gsr head sits 5mm higher than a b16 head. and the intake ports are very different in shape as well.
Hmmmm, my opion:
I have both heads and have searched and done some checking into this myself. Fisrt let me start off by saying that both heads are very good! Stock for stock they are very close in power, usually within 2-4 hp of each other. The gsr (p72) head seems to outperform the b16 (p73) head in the lower rpm under 5000rpm, and the b16 one makes a similar amount more over the 5000 rpm range.
The gsr has a square quench area bumping up compression slightly, the b16 head is a larger round quench area which seems to work well as rpm rises.
Once either head is modified, both heads work equally work from what i've seen.
I have decided to use the gsr (p72) head on my B18C5 block and some jdm itr pistons to bump up comperssion while rebiulding my engine up with stage II skunk cams and valvetrain, it should make some good power.
Deetz
Deetz
jdmstyleEJ6
39
Apr 17, 2010 07:03 PM
