Taking out the WHOLE dash...
Old Jul 29, 2004 | 11:46 AM
eL's Avatar
eL
Default Taking out the WHOLE dash...
Anyone have a write up or some kind of directions for the easiest way to totally remove an EG/EJ2 dash?
Old Jul 29, 2004 | 11:52 AM
Smith Wise's Avatar
Default Re: Taking out the WHOLE dash... (eL)
just go at it some tools... mostly bolts and clips.
spend $10 on a haynes or get a helms for detailed info...
or ask him...
https://honda-tech.com/zerothread?id=600430
Old Jul 29, 2004 | 11:53 AM
hookedonvtec's Avatar
its pretty simple. its pretty hard to get the freaken AC stuff out from behind the dash. take out the glove box. then the center consol thing. then just take the bolts out from behind the clock and the ones under the dash and on the side. its pretty simple. but if u get into the wiring like i had to do when i ran da new wiring harness, its a bitch. lol. good luck
Old Jul 29, 2004 | 11:54 AM
JDM EJ1 95's Avatar
Default Re: Taking out the WHOLE dash... (Smith Wise)
yea i would also like to know how to take off the dash so i can replace my dam heater core.
Old Jul 29, 2004 | 11:58 AM
3.3.3's Avatar
Default Re: Taking out the WHOLE dash... (JDM EJ1 95)
becaferul with the heater core....if you **** up the copper pipe, you will need to replace the whole core.
its pretty easy though....remove all the bolts that hold it to the body (there is also one under the vent on top of the dash in the middle...hidden ******)....there are bolts on each side of the dash near the door jam. also be certain to drop your steering columb first. you will NOT be able to remove the dash without dropping it.
disconnect all the plugs to all the **** on the dash.
thats how i did it...
Smith Wise's Avatar
maybe this will help a little more, but its from my ek. it's all basically the same, nuts, bolts and clips
https://honda-tech.com/zerothread?id=636033
Old Jul 29, 2004 | 12:01 PM
oh yea. u gotta unbolt the two bolts for the AC thing in the engine bay. its kinda hard to get too. but u gotta take them out to get the AC **** out. they are kidna on the passanger side and about half way up from the bottom of the engine bay.
Old Jul 29, 2004 | 12:07 PM
eL's Avatar
eL
Oh man. All these lil extra things just made me think twice about putting a teg dash in... which is why I need to remove my current dash...
Any advice?
Old Jul 29, 2004 | 12:10 PM
JDMisGOOD's Avatar
Default Re: (eL)
Just un-bolt the bitch...stop unbolting things when it pulls off!
Old Jul 29, 2004 | 12:11 PM
3.3.3's Avatar
Default Re: (eL)
well, keep in mind you gotta rewire like...everything! to make that work. you will also no longer have door panels.
Old Jul 29, 2004 | 12:12 PM
JDMisGOOD's Avatar
Default Re: (3 3 3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3 3 3 &raquo;</TD></TR><TR><TD CLASS="quote">well, keep in mind you gotta rewire like...everything! to make that work. you will also no longer have door panels.
kind amakes it not worth it if u say it like that... just buy a heat gun and re-use ypour stock ones
Old Jul 29, 2004 | 12:14 PM
3.3.3's Avatar
Default Re: (JDMisGOOD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD &raquo;</TD></TR><TR><TD CLASS="quote">
kind amakes it not worth it if u say it like that... just buy a heat gun and re-use ypour stock ones</TD></TR></TABLE>
yep...someone actually did a really nice job...lemme look. he was helping me find a dash.
Old Jul 29, 2004 | 12:15 PM
JDMisGOOD's Avatar
Default Re: (3 3 3)
yep...someone actually did a really nice job...lemme look. he was helping me find a dash.</TD></TR></TABLE>
yeah i have seen them both ways...hacked up and done right...
eL's Avatar
eL
I read somewhere that I could just use the teg harness to make things much easier... is that true?
Old Jul 29, 2004 | 12:17 PM
JDMisGOOD's Avatar
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">I read somewhere that I could just use the teg harness to make things much easier... is that true?</TD></TR></TABLE>
Just get the two manuals and cut and splice its quite easy!
Old Jul 29, 2004 | 12:18 PM
3.3.3's Avatar
Default Re: (eL)
im not sure....if you can, damn that makes everything a breeze, but if not, you have to do a lot of rewiring. expect downtime.
Old Jul 29, 2004 | 12:19 PM
eL's Avatar
eL
Any pictures of the door panels "done the right way"?
Old Jul 29, 2004 | 12:20 PM
JDMisGOOD's Avatar
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">Any pictures of the door panels "done the right way"?</TD></TR></TABLE>
Basically u just have to Heat the hell out of your door panel...and "squish" it into the dash when u close the door...
Old Jul 29, 2004 | 12:21 PM
3.3.3's Avatar
w/o panels....you have to use a heat gun on the sides until its soft. once its soft, close the doors and let it harden. done!
Old Jul 29, 2004 | 12:22 PM
JDMisGOOD's Avatar
Default Re: (3 3 3)
...lol god i love H-T
Old Jul 29, 2004 | 12:25 PM
3.3.3's Avatar
https://honda-tech.com/zerothread?id=285567
here ya go!
Old Jul 29, 2004 | 12:28 PM
menkio's Avatar
Default Re: (3 3 3)
and you shound love us!... hehe but yea the dash is just a pain in the *** cuase of the angles, cramped space and silly number of bolts. Just go in and remove every bolt you see... took me like 20mins altogther the first time, now i can do it in 5 mins or so.
Old Jul 29, 2004 | 12:30 PM
3.3.3's Avatar
Default Re: (DewMota)
lol....i snapped a bunch of **** off mine (corners, brackets, etc)
i got pissed and kicked it, and snapped off the vin tag. when i went to register my car, they sent me to the CHP since it looked "tampered with."
lmao
PATIENCE IS KEY
Old Jul 29, 2004 | 12:38 PM
JDMisGOOD's Avatar
Default Re: (3 3 3)
lol yes patience is the key!
Old Jul 29, 2004 | 12:41 PM
eL's Avatar
eL
Man, All this crap is scaring me. lol. I HAVE A BROWN INTERIOR! I really want this teg dash in my car. The teg that i'm getting the dash board is my friends and its just sitting in the drive way so I can take out EVERYTHING I need to make this happen.
I'm just confused as what I will need to remove from the teg and take out from my civic to get it all working right. Then theres the wiring I might have to do and getting everything to fit is a bitch. Damn, im stuck.
