Clicking from front wheel wells when turning
Old Jul 29, 2004 | 07:00 AM
Honda Family's Avatar
Default Clicking from front wheel wells when turning
Hi,
I have a '94 Accord and when I make turns I hear this loud clicking noise in the the wheel wells. It happens both on right and left turns. The car has 120,000 miles. I think it may be the cv boot, but what else can it be and how mcuh am I looking at to reapir it. Thanks.
Old Jul 29, 2004 | 09:16 AM
H2290's Avatar
Default Re: Clicking from front wheel wells when turning (Honda Family)
That clicking is probably your CV joint as you expect. You can always just get the boot which is messier, cheaper, and in my opinion more risky as you may have dirt on the joint itself which is not good.
Or you can get the whole CV axles which you can probably find installed for like $100.
Old Jul 29, 2004 | 12:25 PM
2+2=5's Avatar
Default Re: Clicking from front wheel wells when turning (H2290)
sounds like it but for the sake of butt dyno, check it out one more time.
look for a empty flat parking lot at night, go make some circle, around 30 mph, if there's any damage to your CJ axle, you will hear the click.
dont forget to check the other side also.
you are looking at 100 per side
Old Jul 29, 2004 | 01:30 PM
mozzy's Avatar
Default Re: Clicking from front wheel wells when turning (2+2=5)
I had the same problem.
It could be the endlinks. I had the same problem, but I had the clicking noise while turning AND when I hit any bump on the road.
https://honda-tech.com/zerothread?id=902516
try this post. I changed it myself. Was very easy.
Old Jul 29, 2004 | 04:25 PM
Stealerships are quoting me $370 parts and labor per side. How hard is this to do? Do I need a lift? Even Firestone quoted me $470 for both sides.
VTECdohcter
Feb 14, 2009 07:50 PM
WhitEdRift
Mar 11, 2004 08:48 PM
THE GAME IS THICK
12
Jun 29, 2003 12:15 PM
AGPSuperstar
11
Feb 13, 2003 04:44 PM
REDBARON
14
May 24, 2001 07:25 PM
