Can A Usdm head work on a Jdm block
I have a 92 Jdm h22a that I put in my 90 accord upon driven it, I felt a lack of power so I did a compression test and come to find out the compression was all out of whack Number one was like at 160 and number 4 was at 270 so I ordered a headgasket but it could be bent valves to so I have a usdm 98 h22a4 head at home. I was wondering if the valves are bent can I just swap the heads. I dont think its my ring cause the compression test was done 4months ago and today it is still the exact same. and how can I check for engine codes with a p13 ecu in a accord
yes you can just swap the head, our prelude modorator Joel satan_srv was using a h22a head on a h22a4 block, so the heads can be swapped so a h22a4 head will work on the h22a block, no problem at all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matix »</TD></TR><TR><TD CLASS="quote">In my accord (5th gen) you have to jump the connector with a paper clip or a wire. Its under the glove box ,i thinks its blue or orange. Then it will flash the codes.</TD></TR></TABLE>
WTF??!??!?!?!??!?!?!??!
bolt up? yes it is bolt up. Everything is bolt up in my engine bay
, no JB Weld anywhere. But yes it is a direct run-of-the-mill project. Nothing fancy or out of the ordinary.
Pirate
, no JB Weld anywhere. But yes it is a direct run-of-the-mill project. Nothing fancy or out of the ordinary.Pirate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">you would need a special JDM manual written in JDM to make that work though.</TD></TR></TABLE>
cool...I'll keep a not of that.
