Just got a 96 Coupe.. what to do?
well I just got a 96 coupe... it has around 50k miles on the motor..
what do you guys usually recommend done?
right now i am planning to.....
replace the front axle (goingout)
oil change
bled the brakes and change the pads if need be.
what else?
oil change
what else?
You could check the eg/ek civic forum since you have an ek not an ef
But they will probably tell you the same thing either turbo that bad boy or do a swap. Either b series or the new craze, the k swap either one will work.
What to do what to do! Hmm this is a really hard one, my first move would be to the EK forum, since that is the car you have. Next would be wings, wheels, and kit, NO ****
