DC seats in DA
i know the rear seats won't fit and the front i know with gsr seats only 3 bolts bolt in, you could drill another but its not really needed. i forgot if the rear seats are shorter or soemthing like that, but that is just what i have read.
Rear seats will not fit... the DA cushions (the bottom piece for sure) is larger and wider in size. As for the fronts, you can use the DC rails but you need to redrill 2 holes and retap them to bolt them in. Also, the seat sits higher than the DA seats on the existing seat rails, kinda sucked when I had some ITR Recaro seats in the car but I got used it after a week.... grabing the stock shifter is low. I looked at swapping the rails but the pans are a different width, so the DC rails are about 2 inches wider, which is why you need to redrill 2 of the holes if you use the DC rails. After taking the Recaro seats out, I found a clean set of DA cloth seats (originally had leather) and used those until I sold the car.... best feel IMO.
