Hubcentirc rings, all 4 corners, or just front??
Old Nov 27, 2001 | 12:03 PM
jeff652's Avatar
Default Hubcentirc rings, all 4 corners, or just front??
Have 2 sets of CP-035's. The second set came without hubcentric rings. My first set only came with 2. Planning to order some. Wondering should I get for all 4 corners, or just the fronts?
Also, does anyone know the best place to order them (can I order direct from Racing Hart??)
TIA
Jeff
Old Nov 27, 2001 | 01:06 PM
aklucsarits's Avatar
New User
Default Re: Hubcentirc rings, all 4 corners, or just front?? (jeff652)
Assuming your front and rears have the same hub diameter - yes, you should have hubcentric rings front and rear.
I recently acquired a set of wheels that required the rings, and I had a hell of a time finding anyone that carries them... I knew the exact measurements of the centerbore and hub diameter I needed for my rings. But most places I called (i.e. TireRack) told me they could not sell me hubcentric rings for wheels they did not carry due to liability reasons...
I ended up ordering them from Walee at http://www.Machiii.net. I've gotten stuff from him before, and he is a really nice, helpful guy. They were $20 shipped for a set. (And I'm hopping that they will be delivered outside my door when I get home tonight...)
I think he only carries plastic hubcentric rings, but he should be able to get some for your application...
Andrew
Old Nov 27, 2001 | 01:25 PM
Chris's Avatar
Default Re: Hubcentirc rings, all 4 corners, or just front?? (aklucsarits)
Jeff. If you are going to be racing on them, get the aluminum ones..the plastic ones will melt(?)
And use all four. For 15" rims they are not all that necessary. The purpose is to remove alot of the stress to the wheel studs. They're more important with large wheels like 17's But wont hurt to use them.
Old Nov 27, 2001 | 01:33 PM
chad's Avatar
Moderator
Default Re: Hubcentirc rings, all 4 corners, or just front?? (Chris)
that is good info chris....and yes they will melt if you are racing with them!! i know from experience....but it was just street racing (like the canyon runs in cali but here in va)
Old Nov 27, 2001 | 01:50 PM
Gansan's Avatar
It may depend on what brand of plastic rings you get, but the ones I have won't melt no matter how hot I have gotten the rotors. They are made of the same plastic as those cooking utensils, so that they do not melt with heat.
Old Nov 27, 2001 | 02:23 PM
New User
Default Re: Hubcentirc rings, all 4 corners, or just front?? (chad)
Aw crap! I did not even think of that... I knew that they would be weaker than metal ones, but it did not occur to me that they could actually melt!
Where can I get metal rings from? I need ones with a wheel bore of 2.870"/73.00mm and a hub diameter of 2.525"/64.15mm... These are to fit a set of discontinued Stern wheels that have never been officially sold in the U.S.
Any suggestions on vendors to check with?
Andrew
Old Nov 27, 2001 | 02:25 PM
typerlover's Avatar
New User
Call up tirerack and ask them. I know that for my kosei's that I ordered from them they came with rings, so maybe they can help you out.
Old Nov 27, 2001 | 02:29 PM
New User
Default Re: Hubcentirc rings, all 4 corners, or just front?? (typerlover)
Thanks, but we covered that already. I called Tirerack twice. And both times they told me they could not sell me hubcentric rings for wheels that they do not carry. I had the exact measurements of what I needed. But 2 different salespeople insisted that they could not sell them to me for liability reasons... I guess they are worried that if they did not fit or something, and I damaged my hub or wheel studs, it could be dangerous...
Andrew
Old Nov 27, 2001 | 03:12 PM
nsxtcjr's Avatar
New User
I went to Tire Rack earlier this year and spoke with their expert on fitting hubcentric rings. He didn't mention liability concerns. He told me they don't sell the rings (other than with a set of wheels) because they can't be sure they'll fit, unless they have the wheels there so they can machine the rings in the exact dimensions needed.
Old Nov 27, 2001 | 06:49 PM
ic108's Avatar
New User
all 4's. dont half *** it. racing zone here in tampa has them. they are the biggest DAZZ deler on the east coast. 813-936-0206. ask for mike
Old Nov 27, 2001 | 06:50 PM
Chris's Avatar
Default Re: Hubcentirc rings, all 4 corners, or just front?? (ic108)
Thanks Gansan.
Old Nov 27, 2001 | 08:16 PM
vwong's Avatar
Default Re: Hubcentirc rings, all 4 corners, or just front?? (Gansan)
hm...the rings that came with my CP-035s didn't melt, but 2 of them cracked. I'm not sure when they cracked, but I assume it was back in July when I went to the track event with the outside temp of over 112 degrees F. It was so hot that after the 1st 20 mins. session, my brakes were smoking and the red paint on the calipers turned burgandy. Anyway, I might be looking for a set of hubcentric rings in the near future as well, but this time I want aluminum ones.
Old Nov 27, 2001 | 09:41 PM
Andrew Sites's Avatar
Well damn Glen, you need to tell me where to find these *miracle* hubcentric rings. I just ordered 8 more for my Kosei K1s from Tire Rack, because the originals have either warped or cracked.
Turbo B18C EJ6
Jul 19, 2012 04:49 PM
a1320honda
Jun 29, 2009 07:09 AM
asubennett
Dec 10, 2005 12:29 PM
KraZyCHOWMEIN
Apr 1, 2005 08:28 AM
DLB1994
Jul 4, 2002 02:33 AM
