How long will a oem clutch last with turbo?
Hey guys, i was wondering how long a stock oem clutch with about umm, 40,000 miles on it, last with turbo about 5-7 psi if i ran it hard......like will it burn up in 1 run? or will it last me 20 or 30 runs?
hmm, you might, my friend has a 90 supra turbo on stock boost, with a boost leak, so he was only running 1lb. maybe 2lb's.. on the oem clutch.. brand new, he did 3 launches from 4.5k and burnt it up. we had to tow his car home.
that'll give you an idea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integgedout »</TD></TR><TR><TD CLASS="quote">Hey guys, i was wondering how long a stock oem clutch with about umm, 40,000 miles on it, last with turbo about 5-7 psi if i ran it hard......like will it burn up in 1 run? or will it last me 20 or 30 runs?</TD></TR></TABLE>
It depends how hard you launch and How, If you pop it AND it holds your good.. If you shift and it holds your good. If you slip it HARD on launch your screwed and slip while shifting to avoid wheel spin your screwed
maybe One good day at the track? I have no clue
my 250ft-lbs clutch is pretty fucked after about 2 months. it slips like a bitch if i try and burnoff without accelerating out (in 2nd)
it used to burn top of 2nd now the clutch slips i think :/
im pushin it a little though i have 240ft-lbs of torque
JENNY_EG6
Sep 4, 2009 04:11 AM
