how to do 5 lug on 5gen accord?
http://www.accordinglydone.com/tech/tech.php?ID=80
right here ya go..everything you need...and yes, it will work even with your v6 front suspension...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H »</TD></TR><TR><TD CLASS="quote">http://www.accordinglydone.com/tech/tech.php?ID=80
right here ya go..everything you need...and yes, it will work even with your v6 front suspension...</TD></TR></TABLE>
thanks for the link
thanks for the link
It's also a general safety idea, that 5 points carrying the stress of the car are less likely to fail than 4, since the weight and power is distributed in smaller amounts.
Of course what are the chances of 4 lugs failing if they aren't overtightened by wrench monkeys with air tools? Or even of 3 lugs failing? Heck, if torqued correctly even 2 lugs can do the job.
I'd say OEM wheels. That's the only reason I would consider it personally. New TSX wheels = HOT!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FatJoe »</TD></TR><TR><TD CLASS="quote">'prolly the fact he can put different wheels on that are OEM</TD></TR></TABLE>
if i would keep the 4x114 the only oem rim ill get is the 97 spec itr rims
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asti »</TD></TR><TR><TD CLASS="quote">Just a question: what do you gain if you have a 5 nut hub VS. 4 , as the original equipment ?
well, most don't do this in actuality, but in theory you have a better selection of high end wheels, and better choice of brake upgrades...
